Question about Kenmore 44102 Front Load Washer
My door wont open and my clothes are stuck inside. I've a kenmore model 41729042991
  • 15,935 Answers
You will need to remove the kick panel with ?? #10 ??torx bit.
Reach up in the latch area and you will feel a small teardropped shaped handle.
Pull it straight down, and the door will unlatch.
Try unplugging for 5 minutes though... sometimes a hard reboot is all that is necessary to re-sync.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 22, 2009
My kenmore dryer 70s series wont start
send the model number,open the door and look around the opening where you put the clothes in,you'll see a tag with model and serial number,just need model number.
Mar 18, 2013 | Kenmore Dryers
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
My 91 chevy truck is stuck open
SOUNDS LIKE LATCH WAS IN CLOSED POSITION WHEN DOOR WAS SHUT I'VE HAD IT HAPPEN A FEW TIMES PUT A SCREWDRIVER IN THE LATCH OPENING AND PRY WHILE PULLING INSIDE HANDLE...IT MAKE TAKE A TIME OR TWO
Oct 11, 2012 | Chevrolet Cars & Trucks
Sampsung wf7708n6w1 door won't open!
Your door switch/lock is broken, you need to unplug the machine and remove the top, you can then reach down (tight space) and using a small screwdriver you can pry around the switch and get the door to open, you need to get a replacement door switch for the machine.
Leaning the machine back can make it easier to access the switch.
Mar 06, 2012 | Samsung Washing Machines
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore 41729042991 front-loading washer door won't latch closed
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
Kenmore F-28 error - door locked can't get in
Unplug the machine.
Wait 15 seconds.
Plug machine back in.
Press and hold the Power button until the lights come on.
Press and hold Start.
When you hear a click, press Stop.
Open door.
You still have an F-28 issue but you can at least get your clothes now.
Hope this helps.
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer is stuck on spin and the door wont open. It is locked.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 16, 2009 | Kenmore HE2 Plus Front Load Washer
Hotpoint bwm12 intergrated washer drier
BEST YOU GET A TECHNICIAN ITS E VERY HARD JOB TO OPEN A STUCK DOOR CATCH.GOODLUCK.MOHAMED.AND ITS NOT CAUSED BY COIN DAMAGE ITS JUST WEAR AND TEAR ITS A ELECTRICAL COMPONENT THAT CAN MALFUNCTION AT ANY TIME
May 31, 2008 | Hotpoint BWM12 Front Load Washer
Kenmore 44102 Front Load Washer Logo
161 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
