Question about Worx WG788 19Inch 36 Volt Cordless 3In1 Lawn Mower With Removable Batter
Is there a fuse for this mower
The mower I have will start but will not cut. It is a self propelled mower. I got it late in the season last fall, used it a couple of times before winter. Went to use it this season, and as I stated, it will start and move forward, but will not cut. HELP
Lawnmower Makes Squealing Sound when Self-Propell is Used
if you take it apart there will be no warranty . take it to where purchased and get it repaired
Jul 21, 2015 | Troy Bilt 5.5hp Self Propelled Mower
What oil to I use in toro self propelled lawn mover is 5w30 ok
Hi jonconbuck...
5W30 is ok during the winter season...but use 10W30 or 30 W non detergent during the summer season
Please take time to rate me
Sep 11, 2011 | Toro Power Lawn Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
Cub Cadet Selp Propell and Electric Start Stopped Working
Take a look at your owners manual. It should have a parts diagram in it. With the manual in hand take a good look at the self propel assembly. Make sure every thing is there. It could be a spring came off, or belt broke. You might have to take off some covers to check. If you are somewhat mechanically inclined it shouldn't be a problem. I suggest taking a photo with a digital camera to make sure you get everything back the way it should be. Also in your manual it might have a troubleshooting page.
Good luck. Let me know if this helps.
roundo4
Aug 08, 2009 | Garden
My Toro self perpelled lawn mower starts then conks out.
It sounds like your fuel system is plugged up (or water in the carb) First i would make sure there is good fuel supply to the carb, then if so & not running, I would remove the carb and clean as it appears that it is running properly otherwise. Also check your air cleaner element as it may be totally plugged up.. Hope this helps you, Rick
Apr 26, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troybilt self-propelled mower - model 556 won't start
pipe from carb to engine broken. couldn't tell until covers & fuel tank removed. also part of deck holding engine came apart on mine. due to excessive vibration???
Apr 04, 2009 | Troy Garden
Open Questions:
See all Worx WG788 19Inch 36 Volt Cordless 3In1 Lawn Mower Questions
Worx WG788 19Inch 36 Volt Cordless 3In1 Lawn Mower With Removable Batter Logo
35 people viewed this question
Top Worx Garden Experts
Tim Whalen
ray gallant
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
