Question about Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ...
Reset replace maintenance kit message - Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ...
4 Suggested Answers
Ickoajnc
  • 183 Answers
SOURCE: Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Posted on Jul 16, 2009
SOURCE: replacement of the maintenance kit
I need more info or service program for reset sistem infomation (replace maintenance kit) on front panel,
Posted on May 14, 2010
  • 1833 Answers
SOURCE: Maintenance kit has been replaced
To clear this message,you need to reset the fuser again. 1. Shut down the printer and allow itto cool for at least 30 minutes. The fuser gets very hot, and you could burnyourself while changing it. 2. Lowerthe left-hand door to access the fuser cartridge. Remove the duplexer bypressing down on the green button and pulling it out of the printer. Yourprinter may or may not have a duplexer installed. 3. Flipthe two blue clips downward to unlock the fuser cartridge. Lift up slightly onthe blue handle in the center of the fuser cartridge and lift it out of theprinter. 4. Grip the fuser by the blue handleand slide it into the printer until it locks into place. Flip the blue clipsupward until they lock into place. The clips will not flip up unless the fuseris properly seated. Slide the duplex unit back into the printer and close thedoor. Finally reset you printer. Hope this willhelp you. Good Luck.
Posted on Aug 25, 2011
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
80 scheduled maintenance
This issue is just like changing your oil or the timing belt on your car. If you don't fix it correctly it leads to other problems. So, be warned. :+)
Here's what the Lexmark KB says:
On the Lexmark T520/522 series printers, we recommend that the maintenance kit be replaced after every 250,000 pages. If possible, an authorized service technician should replace the maintenance kit parts on these printers.
On the Lexmark T620/622 series printers, we recommend that the maintenance kit be replaced after every 300,000 pages. The maintenance kit parts for these printers are customer-installable, but some dismantling of the rear area of the printer is involved.
Note: The maintenance kit may need to be replaced more often if the customer is running heavy media (like card stock or labels) through the printer.
It is possible to clear the maintenance error message without replacing the kit. The printer will still operate, but some print quality problems may arise. However, this is not recommended as the message serves as a reminder that maintenance is due. If the printer is under warranty, the customer has to purchase the maintenance kit and have it replaced in order to keep the warranty active, although the on-site replacement itself may be covered under the warranty.
The parts that make up the maintenance kits are:
A fuser unit
A transfer roller
A charge roller
To find the part number of the maintenance kit needed for your printer, see Printers / Maintenance kits.
Clearing the maintenance message
To clear the message, you will need to go into the printer's configuration mode. Do the following:
  1. Press and hold the SELECT and the RETURN buttons as you power the printer on.
  2. Hold the buttons for six to eight seconds after turning on the power, then release them. (If you receive the maintenance message, press the Go or the Select button to continue past it.)
  3. Now, press the right Menu arrow until you see RESET MAINT CNT.
  4. Select this. You may need to press the Select button again. The printer display should briefly flash SAVED.
  5. Power the printer off and then back on in the normal way. The printer should now power up normally.
  6. If it does not and the error returns, repeat the above procedure.
Jun 11, 2009 | Lexmark T522 Laser Printer
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
8550DP Maintenance Kit
First of all make sure it is the right kit. The part numbers for teh 8550 and 2424 are very close, one ends in 675 the other in 657, so they have been known to be mixed up.
then here is the documentation..
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
Apr 18, 2008 | Xerox Phaser 8550DP Printer
Maintanance kit replace
Problem:
Cause:
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Ricoh Aficio SP 4110N Laser Printer - Monochrome Laser - Network Printer - 36 ppm Mono - 1200 x 600 ... Logo
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
