Question about Garden
Problems with Yanmar 3TNV76 JD engine
Cannot start turn key till I hear click but it will not turn over?
4 Suggested Answers
  • 202 Answers
SOURCE: Yanmar diesel engine model#3007D003 powering a 6x4 cuts off.
My thought is that it is electrical, since it will not crank. I assume you mean that it will not turn over when you turn the key. I am not certain, but I think that if you have an electrical problem it may shut off the fuel supply as well. There is probably an electrical fuel stop on that machine. Since there is no spark plugs or electrical system to make the engine run, by shorting out the electrical system it will not stop the engine.
Posted on Oct 26, 2009
  • 111 Answers
SOURCE: engine turns over and getting fuel, put has no spark on JD 322
check for cracks in the spark plug wire it sounds like it is shortening out or a ground wire.
Posted on Mar 02, 2010
roadtech7
  • 293 Answers
SOURCE: when I turn the key on my JD 2305 tractor to
105889d1215292605t-need-help-2305-wont-start-2305-fuel-supply.jpg105890d1215292605t-need-help-2305-wont-start-2305-fuel-supply-diag.jpgYou have a bad relay or pull in timer. You have the same M806808 fuel shut off solinoid as the 4000 series tractors. They use a timer/heater called a thermistor. This is common to your simptoms, I just dont see it for the 2305. Talk to your dealer, and ask him to look up a thermistor for your tractor.....Dont let him tell you have a fuel pump problem...Its a scam. Get back with me if they **** you around. The fuel shut off soleniod has three wires, you can check them for voltage. Just disconnect them and check voltage between the black and blue and the black and red. On the tractor side. You will have to crank the motor to start the timer circiut. after you start ( or just hit the key for 2 seconds) you should have voltage on the red ,during crank, and voltage on blue while the key is in the run position. If you do, the problem is in your soleniod. Remove it and do the same thing to confirm.
Posted on Dec 05, 2011
Car would not start when i turn the key . sometimes a hear a click which could be the solenoid. other time i hear no click, it starts after i turn the the key lots of time . the ignition is ok. Could
check for lose wire connection off wires on solinoid and battery solinoid is connected on stater motor normally on the side off engine at the back off engine
Dec 09, 2012 | 2005 Hyundai Elantra
Battery is good but when I turn it on it just clicks won't start,maybe after 20 times it starts
Without hearing the sound it makes - it's kind of hard to diagnose.
The engine starting process consists of turning the key to start, the starter motor's rotor moving forward to engage the engine's flywheel, and then the starter motor 's "rotor" spinning until you move the key from "start" to "run". You can hear the starter motor spinning - but one usually can't hear the rotor moving forward to engage the flywheel. As a result, you hear the odd spinning sound - which is the starter rotor spinning. The engine never actually turns over because the rotor never engages the fly wheel. If this is the case, then it is very likely that your starter needs to be checked and / or replaced.
Nov 09, 2011 | 1994 Buick LeSabre
No fuel pressure till the asd and the fuel pump relay click about 30 -40 seconds after trying to start with the key in the run position ive tested fuel pressure ,,,none till i hear the relays click and...
This is a delay to power the fuel pump. You need to check the output from the ECU/ECM. check for any error codes, check if there is power from the switch. Once the engine runs , you need to see if there is any error codes or faulty symptoms.
Sep 30, 2011 | Cars & Trucks
Engine turns over and getting fuel, put has no spark on JD 322
Mar 01, 2010 | John Deere &Reg Branded 27" Tractor Metal...
Oct 26, 2009 | Garden
Model 425 jd getting fire at plugs changed fuel filter primed carb will not start
when you turn the key on to the run positon do you hear a clicking sound coming from the carburator? this tractor is equipped with a fuel shut off solenoid on the carburator if you dont hear the clicking sound solenoid is either not getting 12vdc or it is defective.
Aug 29, 2009 | John Deere Garden
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
I've just had the same problem
check the fuel cap for a vent it needs to be vented . the air displaces the fuel no vent on fuel try running with the cap off . if it runs the vent was clogged or the wrong gas cap
Aug 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Turn key 4x to build pressure, on 4th try complete Start seq.
is the engine actually cranking when it doesnt start or do you hear just one "click" each time you turn the key? if the engine is cranking, i would suspect a fuel problem, possibly fuel filter if it wasnt changed when the fuel pump was done. if it is not cranking and you hear one "click" upon turning the key, i would suspect faulty starter or connection problem.
Nov 08, 2008 | 1997 Mercury Sable
Garden Logo
46 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
