I have whirlpool cabrio HE low water top loader washing machine. It stopped working in drain & spin cycle so I reset the machine but it won't start . The lid locks and it goes into sensing mode but it won't start working . It just has a humming sound . I followed instructions to start diagnostics test and tried it several times just as shown but it wouldnt work either . This machine is just two years old . I appreciate any help you can give me .
2 Suggested Answers
catriver
  • 878 Answers
SOURCE: Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Posted on Oct 20, 2006
My whirlpool cabrio keeps switching from fill to spin and won’t cycle through the rest.
water level switch indicates water level to low so keep adding water your drain hose may be too low cause the water be sipon out
Feb 12, 2018 | Whirlpool Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool front loader cabrio stopped working with 12 minutes left in the cycle. The Ld code is flashing and I don't know how to fix it so that the load will spin and drain. How do I fix this...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 18, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Cabrio washer won't drain and spin. It says "LD" and consistently stops with 24 minutes left on the cycle. For a while if I would spin the basket a little it would work. Not that...
There could be several things causing this problem. Have any small items gotten caught in the pump or between the basket and tub? You may be using a cycle with a low spin speed. If you need to remove excess water, select the Drain and Spin option. If the load is tightly packed it might cause the problem you're having. Are you using ONLY "HE" detergent? If so, be sure you're using the correct amount. To clean out residue from too much or wrong type of detergent select the "Rinse and Spin" option but do NOT add any detergent.
I hope this information helps. If it does, please rate my suggestion and its effectivness. Thanks!
Jun 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
