Question about Amana Dehumidifiers
What is the average temperature it should be set on?
What are the recommended settings as far as % of humidity and room temperature? Does this set automatically?
Humidity is said to be good at 50% RH and temerature at 77*F. Air looses humidity when it is heated or cooled. Extremely humid conditionals it difficult for air conditioners to cool the air.
The temperature to be comfortable in varies from person to person.
Aug 11, 2017 | Dehumidifiers
How many pints of water does a simplicity 28 dehumidifier remove from the air
It depends the relative humidity of your Region,state,city, season, temperature.
Its only an average about one us gallon a day
Sep 03, 2014 | Dehumidifiers
Why does my dehumidifier run al the time ,i have the humidity set at 45 and when the room temperaturegoes down to 55 it keeps running.
The 45% setting is too low and the setting is never satisfied, so the unit keeps running to try and reach 45%. Try setting to 50 or 55, this is a very comfortable range. I was not clear on the room temperature being at 55 degrees. Is this what your thermostat is set to or is this the actual room temperature. Brrrrrrrrrrrr
Sep 01, 2011 | Fedders A7DH45B2A Dehumidifier
My Danby DDR583R dehumidifier no longer dehumidifies unless I set the humidistat to the lowest, constant run setting--then the compressor kicks on. The humidity reading says 14% which I know to be...
There are a several things that can mimic a faulty humidity sensor.
1. The air intake filter is clogged and needs to be removed and cleaned.
2. The coiling coils need to be cleaned.
3. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If the above fails to help solve the problem, replacing the Humidity Sensor is certainly an option. But, before you jump into it, make sure you have an accurate wiring diagram, so you know which sensor is which. As the part does not come with installation instructions.
I hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | Danby DDR583R Dehumidifier
THE UNIT DOES NOT DEHUMIDIFY, MODEL HD456E, I SET THE TEMPERATURE TO 50 AND IT ALWAYS SHOWS THE WORD "LO" AND WILL NOT RUN, UNIT HAS LESS THAN 200 HRS. WHAT DO I DO? unit was purchased at menards...
You are setting the temperature to low. Dehumidifiers do not work well between 40 - 60 degrees F. That's why the word "LO" keeps showing up. Raise the temperature setting and set the humidity extraction level (Arrow Down) at 30-32%. In fact, if you can disregard the temperature setting and the unit will work, do so. That seems to be the fly in the ointment, when it comes to getting everything to work as it should.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 17, 2011 | Haier HD456 Dehumidifier
What is the right temperature setting when the room has a lot of water?
You can't control the temperature setting but you can control the humidity level. I would start somewhere between 35 and 40%- making sure to empty the dehumidifier promptly when full. 40% humidity will prevent mold and mildew growth- and that musty smell- but keep the room from becoming too dry.
Mar 01, 2011 | Kenmore 54501 Dehumidifier
Just wanna know how to set the temperature on it
dehumidifiers do not have a temperature control, rather, they have a humidity control. usually you set the humidity control to go off when the level of moisture in the room reaches normal (approx. 25-35% winter;38-55% summer). Best way is to run it at full on for 1 to 4 days (until you know the moisture level is how you want it), then turn the knob until the unit goes off . This will be the ideal setting. Goodluck<Macgivor
Jan 16, 2010 | DeLonghi DDE40E Dehumidifier
Settings? how do I set the temp on Danby DDR601
Since the DDR601 is a deshumidifier, there's no temperature settings. It's built for humidity control, not for temperature control.
Aug 13, 2009 | Danby DDR601 Dehumidifier
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Question on temperature range
Most dehumidifiers run between 42 degrees and up. If you need one for lower temperatures you can buy special ones. If you have cold temperatures in your location the air is usually dryer in the winter so the dehumidifier is not really neaded during that season. The average humidity setting you would want to run it at is 60 Percent. It will keep your basement from becomming damp and also keep it from running nonstop. Good luck and if you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Jun 04, 2008 | Kenmore 54701 Dehumidifier
Dehumidifiers Logo
49 people viewed this question
Top Amana Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
