Question about Garden
How to install drive belt onjohn deere stx 30 lawn tractor?
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
bbreton
  • 437 Answers
SOURCE: need instructions for changing a drive belt on a John Deere LT155
I have googled LT155 and came upon john deere LT155 lawn tractor(noncurrent). It took me to John Deere's site. I put in your model number and it had several catagories. I would try the alphabetical list, go to B and look for traction belt.
Good day.
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
I need a drive belt routing picture for a John Deere x300 mower
For a routing or installation diagram, contact John Deere directly.
Sep 11, 2017 | John Deere Garden
John deer l111
Replace the belt tensioner and belt.
Jul 08, 2013 | Garden
Stx 30 Starts, runs until attempt to engage electric clutch.Thanks
I have a John Deere STX30. I can start it, but when engage into gear it die completely!
Jul 06, 2011 | John Deere Lawn Tractor Seat F710 F725...
I have a john deere stx 38 lawn tractor that I was cutting my grass with when the blades just stopped working. When I turn the switch on and off it makes a clicking sound but still won't work. What should...
Make sure the blade drive belts are still on. I believe the click sound you are hearing is the electric blade clutch turning on and of with the switch which means it is probable ok .
Sep 17, 2010 | Garden
Need instructions for changing a drive belt on a john deere LT155 lawn tractor. When mowing up hill the forward motion is slipping even though i am not loosing traction. if i come off the pedal and start...
Good day.
Oct 14, 2009 | John Deere Garden
John deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Jul 14, 2009 | John Deere Garden
Jul 12, 2009 | Garden
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
