Error code f 82 Whirlpool cabrio
How do i reset the internal computer
s_4u_11
  • 535 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
Posted on Sep 16, 2008
  • 3 Answers
SOURCE: keep getting LD error code on whirlpool cabrio washer
Is there water in the bottom of the tub? If yes then open back of washer and remove drain pump (on left side) and pull off of tub and clear whatever is blocking its impeller.
If the water is all gone and drained but pump stays on for several minutes and then gives "LD" fault then open back and check the small clear tube that is attached to the tub. Make sure is not blocked with debris and check tube and tub for anything that could block the small clear tube. If these are ok then remove 3 screws in back of the control panel, pull open control panel and check the clear tub all the way up from the tub to the washer controller board (computer) make sure it is not kinked or disconnected. If not then the problem is most likely the pressure sensor on the (computer). This unit will have to be replaced.
You can test the sensor by doing the following: 1. When the "LD" fault comes on start by pressing the pause button. then pull the clear tube off of the computer board. Then attach a tight fitting drinking straw over the sensor. Press the start button and wait for 60 seconds - If the washer does not start the spin cycle on its own after the 60 seconds then **** on the drinking straw that you attached to the pressure sensor earlier. The sucking action should reset the sensor thus telling the computer that the water is drained and it will start the spin cycle. Just remember if you have to do this to get the washer to spin - that means the sensor is damaged most likely from moisture traveling up the tube over time. The computer board will need to be replaced. I believe it costs $205 without shipping. Hope this helps.
Posted on Apr 05, 2009
  • 3 Answers
SOURCE: My Whirlpool Washer Cabrio model# WTW6200SW has a
Called 1-800-253-1301 was told by the Whirlpool agent that there was a quality issue associated with the F1 fault code. They would take care of parts and labor free of charge! My machine is 28 months old. Talked to a woman named Valerie.
Posted on Apr 19, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
SOURCE: F50 error code and Whirlpool Cabrio
JUST SPOKE WITH WHIRLPOOL ABOUT THE F-50 CODE. THEY SAID THAT THEY ARE AWARE OF THE PROBLEM AND THEY ARE PAYING TO FIX IT. ALSO THE CONTROLL BOARD AND THE RPS SENSOR MUST BE REPLACED TO FIX THE PROBLEM. THE OWNER MUST CALL WHIRLPOOL, NOT THE TECH, TO GET THEM TO PAY FOR IT. HOPE THIS HELPS.
Posted on Mar 29, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
    Slow drain code. How high is the outlet pipe ABOVE the machine?
    Jan 05, 2016 | Washing Machines
    What does the code F2 mean in the time window of the Whirlpool Cabrio gas dryer and how do I reset the machine?
    Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes
    • PF--Power failure
    • AF--Restricted air flow
    • F01--Primary control failure
    • F02--Keypad/User Interface failure
    • F22--Exhaust thermistor open
    • F23--Exhaust thermistor shorted
    • F24--Inlet thermistor open
    • F25--Inlet thermistor shorted
    • F26--Motor drive system failure
    • F28--Moisture sensor open
    • F29--Moisture sensor shorted
    • F30--Restricted air flow
    looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
    Sep 07, 2012 | Whirlpool Dryers
    Whirpool Cambrio Has A F1 Code
    Well error F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed.
    First of all you may leave unplugging the washer from the wall, leave it unplugged for a while. That may reset the internal computer chip. If further you have the same problem then it need some part (chip) replacement need some skills of electronics, part is $150 CODE 083009 part W10189966 CNTRL-ELEC. Post comments for further help or information...........
    Good Luck!!
    Thanks for using FixYa!!
    Oct 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    The screen reads F1?
    Good Luck!!
    Oct 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Getting a F1 code, how can I reset it. Can afford professional service.
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Jul 30, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Fault code F1 is flashing on my cabrio washer
    I have just gotten off the phone with Whirlpool for an F1 error on my cabrio washer. They are arranging for someone to come and fix my machine at their cost. It appears to be a common problem. Call Whirlpool and set it up. Good Luck.
    Jan 11, 2010 | Whirlpool WTW6400SW Cabrio Washer
    My Whirlpool Washer Cabrio model# WTW6200SW has a F1 error (fault) code? Does anyone know what this is and how to clear/reset the code?
    Mar 18, 2009 | Whirlpool WTW6400SW Cabrio Washer
    this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
    Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
