Question about Peavey 03513340 PV8 USB 8-Channel Mixer
Does a peavey pv8 usb mixer have a fuse somewhere inside its casing?
  • Peavey Master
  • 3,368 Answers
Check your service or user manual.
Posted on Nov 27, 2014
The voltage out from supply just jumping all time from about 38,1V constantly to 46,4V - WHY??? How many VOLTS should be????
1- Are you measuring with the mixer connected ? The supply needs a load to work right.
2- If so, you have a blown regulator inside the supply, or maybe a bad solder somewhere on the board, probably a condenser...
LUCK---
Feb 16, 2015 | Peavey PV10 USB Mixer
Pv8 setup karaoke
Are you using a karaoke machine? Make/model?
May 03, 2014 | Peavey PV8 Mixer
Clip light on
Does all the "Clip" lights are on? or just certain channel? if all "Clip" lights are on you have to check the +15V and -15V at Operational amplifier ic that is a 8-pin integrated circuit, pin 4 should have the -15V and Pin 8 should have the +15V, if just one channel shows the light constant on then its an opamp in that particular channel, let me know further to improve help.
Oct 24, 2013 | Peavey PV8 Mixer
How can you tell if a fuse is blown on a XR 8600 power amp by peavey?
The fuse is probably placed near the power cable entrance in the power amp.
Pick it up from it's placing dock and look for the wire inside. If the wire is whole, the fuze is fine, however, if the wire inside the fuze is missing or burned, the fuze needs to be replaced.
Jan 27, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
I can`t get any sound from my pv8 mixer i put the speaker cable i have put the red & white phonos into the mixer from my laptop getting on sound from the clip at all please can you tell me where i am...
Several things to do: Plugging into the tape type inputs... say the 7/8 channel.
The little button below the set you plug into needs to be pushed to the down position. This selects the "B" set which are the RCA jacks.
Below the set you are plugged into. Turn up the top knob "Gain" until the "clip" LED just isn't quite flashing.
At the bottom of that same column Turn up the "level" as needed for the mix.
Then of course, advance the Master level as needed.
May 13, 2011 | Peavey Electronics Peavey Pv8 6-input...
All the clip lights come on when connected to mains power
Power supply +15V and -15V failure, pay special attention to regulators.
Apr 08, 2011 | Peavey PV8 Mixer
PV 1500 Amplifier
The final out put amp stage is out. MOSFET transistors likely. Hope this is helpful.
Jan 07, 2009 | Peavey Music
Peavey 03513340 PV8 USB 8-Channel Mixer Logo
143 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
