Question about HP TOUCHSMART IQ526 PC PC Desktop
How to replace i526 fan stopped - HP TOUCHSMART IQ526 PC PC Desktop
The fan has stopped working the receiver is not working. What component has to be replaced in the receiver I.E Diode,capacitor etc.
FAN STOPPED WORKING? Fix it! - YouTube
? 7:40
https://www.youtube.com/watch?v=5WOdTVz2NlY
Jul 11, 2010 - Uploaded by Generatorblue Generator blues
Now it has to be replaced with same rated replacement. Brand makes no differenc3. Just rating. And then fan ...
Electric fan repair: Blades don't spin - YouTube
? 1:20
https://www.youtube.com/watch?v=RIUtBWJeJDE
Aug 21, 2012 - Uploaded by 1000uf
A simple fix for your fan that doesn't start. ... And also stop. thanks .... Please see my other fan repair video in ...
How to Repair a Ceiling Fan ' HomeTips
Dec 14, 2015 | Dryers
Fan makes noise on my Dell Inspiron One 19
Usually there is a fan on the CPU heatsink and a fan in the power supply.
Open the case and turn on the computer and use a small timber stick and poke it into the CPU fan to stop it spinning and if the noise stops then this fan needs replacing.
If it is OK the the fan in the power supply is faulty. I recommend you replace the power supply because there are dangerous voltages inside this power supply.
Jul 31, 2012 | Dell Inspiron One 19 (884116044949) 185 in...
The engine cooling fan will not stop. Battery was dead yesterday, needed new one, put it in, then fan started and would not stop (for hours)had to disconcect the battery. What is wrong?
  1. locate the engine cooling fan relay/disconnect/does fan stop
  2. if so reconnect relay
  3. locate fan switch in radiator or intake manifold
  4. disconnect switch/does fan stop?
  5. if so replace switch
  6. if not replace relay
  7. this solution does not check for electrical wiring problems
  8. such as opens or shorts to ground
Jul 27, 2010 | 1994 Honda Accord
Fan stopped working
Try to turn the fan by use of a long screw driver or other object. If it feels like it is siezed or getting very hard to move then the fan motor needs replaced. If it turns freely I would replace the capacitor and if that does not solve it then replace the fan motor too! Capacitors are cheap and fan motors are $80 to $120 average!
Jul 08, 2010 | Weather King 10AJA4201AH Air Conditioner
FREEZER FAN HOWELS AND STARTS AND STOP STARTS AND
Your freezer fan will need to be replaced to keep it from stopping. Try to find the complete model number so I can help you fix and or replace the fan. Let me know, Thanks, Sea Breeze
Mar 21, 2009 | GE Freezers
PSU problem. Power on, fans spin then stop. 15 secs pass fans try to spin then stop and so-on ?
Hope your system is running and only the fan is not running. in that case fan needs replacement. only the fan can be replaced. good luck
Dec 18, 2008 | Computers & Internet
Nutone fans all three less than 4 years old, hum or squeal
I would recommend just replacing the motor's in the fans. It is a lot easier than taking the whole unit out to replace it. The motor for your fan sells for about $65.00.
Nov 15, 2008 | Broan-NuTone (8663RP) Ceiling Fan
GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Jul 22, 2008 | Heating & Cooling
HP TOUCHSMART IQ526 PC  PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
