Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Dryer Model # 11085866400
Model # 11085866400 computer panel problem after only one load drying the computer light beeps and jumps to all different cycles, I have to unplug the dryer for a while and then it drys one load normal and a couple minutes later the same thing happens the light comes on it beeps and the light jumps from cycle to cycle
SOURCE: Kenmore Elite Oasis Dryer 67086 beeps!
I have been experiencing the same constant beeping throughout the drying cycle with the loud and soft lights alternating. After reading every post I could find related to this issue. I removed the top console and found the hidden tech sheet. I ran the diagnostic mode and got error code F 2 which means there is a failure or interface mismatch, whatever that means. Well, when I read that folks have spent hundreds of dollars to replace the part and the problem returns and since the dryer functions perfectly fine except for the beeping, I just removed the beeper from the control board (twisted it off). Crossed my fingers and put everything back together. Turned on the dryer and bingo, beep is gone and dryer works fine. I know this isn't a proper fix, but Sears doesn't have one either. I had a Sears Tech to my house right before the warranty expired and she had no idea what to do and said the dryer was so new, they didn't have any specs. She didn't even remove the top to get the tech sheet and check any of the connections or run the diagnostic test? Just kept pushing different buttons and unplugged and it seemed to reset, but of course came back. Hope that helps someone else who doesn't have the money to replace and knows that Sears won't do it. Good luck!
Posted on Nov 15, 2007
  • 156 Answers
SOURCE: Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Posted on Feb 28, 2008
reg501
  • 413 Answers
SOURCE: Cycle Signal Beeping
The user interface button panel has failed and will need to be replaced.
Posted on May 29, 2008
SOURCE: Kenmore Elite Elec Dryer Model # 110 62032100
Kenmore Ellite Dryer - Model 110.73952102 Type DDOT - NAT 1206006 - EH22
The Heat does not turn on! It spins and spins but no Heat? Any suggestions and how to fix intructions would be greatly appreciated. Thank you!
Posted on Nov 03, 2008
  • 163 Answers
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
Kenmore Elite Model 110..71082000 Gas Dryer wont stay on to dry clothes
If the dryer lights and then goes out, you will need to replace the flame sensor. Here is the part to order.
Nov 06, 2012 | Kenmore Elite 45986 Front Load Washer
My Kenmore elite HE4 quiet pak 9 electric dryer is working, but it emits a constant series of 3 beeps, and sometimes shuts off before the cycle is complete. I have to unplug it to stop the beeping....
You are getting moisture in the control panel buttons. After a while the panel will not function at all. The light in the dryer tub will still come on when the door is open. When you unplug your machine and it sets for awhile you are allowing the moisture to dry and the machine can reset. Some people use a hair dryer to dry out the control panel for a temporary fix. Eventually, you will have to get it replaced once it stops resetting for you.
Oct 25, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he4 dryer-model#110.95087401 keep beeping and the end of cycle lights are going on from off to high and back to off right through the drying cycle.
I had the same problem and eventually none of the cycle buttons light up or the cycle time display. So it would not run at all. After taking it apart once and fiddling with the cycle push buttons, it worked for one load then would not work again. I could see 3 of the led faintly illuminated and unplugging and plugging back in the power changed nothing. Then I removed the plastic ring of cycle buttons that is between the panel circuit board and the outer plastic. (There a several layers to get to the ring.) Now I use a long allen wrench to push on the switch on the circuit board. I left the middle start button in place. That does not seem to cause a problem. Several loads now and still working. So it looks like the ring on plastic buttons don't release from the circuit board buttons causing a problem.
Feb 21, 2010 | Kenmore Elite HE4 Electric Dryer
When I push start it beeps 3 times. Lights on the right work, lights on the far left don't light up.
Alright, pretty unconventional, but simple and Genius on my part!!! Not sure if we're talking about the same models, but I was cruising this site with the same problem.... K, so it's making three beeps right? Check inside the DRYER (maybe same issue w/ washer, I dunno), but there's a button on the top-inside.... DEPRESS THAT BUTTON, and while holding it down, START THE DRYER (HOLD TO START), if it starts working, this tip is for you!
1) on the opposite side, where the door depresses that same button on the dryer door... you ready for this... see step two ;)
2) SUPER GLUE A PENNY IN THAT INDENTATION PART, your problem is there's not enough connection, and the door is no longer holding that same button down...
3) TA DAH!! Since a repair guy could've charged ya like 50+ bucks, I'll take... emmm.. 25$, email me at Kumatrev@yahoo.com on where to send the check, or just shoot me an email to say thanks ;)
May 29, 2009 | Kenmore Elite HE4 Electric Dryer
Oct 14, 2008 | Kenmore Elite HE4 Electric Dryer
Apr 19, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Nov 27, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
