Question about Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7
Power cord replacement for frigidaire LRA050XT7
Get front grill off
Our Frigidaire FRA256ST2 is only four years old. This morning I went to turn it on and absolutely nothing happened. The unit is getting power through a 220v outlet because the green light is on on the...
Just because the green light in on, on the power cord it doesn't mean that the unit itself is getting power. There could be several problems. One being the switch itself or a loose or burnt wire. You probably would be better off calling a qualified servive technician.
Good luck,
Marty
Jun 20, 2014 | Heating & Cooling
Took it out of Box, Pluged it in to First Make Sure it Worked and It VIBRATES So Bad Im Scared to Install it.....What should I do?
If you think something is wrong with the air conditioner, you take it back to the store. No a new air conditioner should not vibrate violently. They are pretty quite, so take it back to the store, and exchange it for another one.
Apr 07, 2014 | Frigidaire 5000-BTU Window Room Air...
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
Looking for a power cord for a wolf gang puck indoor grill model #CCRG0030
Replacement parts for BRGG0010-0020 can be gotten from the cookware site below but your particular model of the grill seems not to be available.
So my candid advice would be to get in touch with their customer service and ask for their help with getting the power cord for your particular indoor grill.
http://www.wpcookware.com/products.asp?cat=80
I hope this helps you.
Sep 14, 2011 | Wolfgang Puck Reversible Grill and Griddle
Hi, i need to know where can i download an owner's manuals for the frigidaire galleries series grill mo.# GL51 LPDC. My main reason to br able to buy replacement parts.Thanks for your help on this matter
I don't believe that Frigidaire is making grill any more, but are being manufactured by another company that bought the rights to use the Frigidaire name on the grill.
In any event, Sears Parts has an exploded view of your model grill, which shows all the parts and you can order then from Sears Parts Direct. Just enter the model number of your gill and it will pop up.
www.searspartsdirect.com/
Feb 06, 2011 | Frigidaire GL51LPDC (LP) Grill
New Plug and Cord for Wolfgang Puck® Reversible Electric Grill/Griddle
I also need a replacement electric cord for the Wolfgang Puck Reversible Grill. Please let me know if you are able to locate one.
Oct 19, 2008 | Wolfgang Puck 781698 Indoor Grill
Frigidaire 5000-BTU Window Room Air Conditioner LRA050XT7 Logo
70 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
