Question about Brodit ProClip for Hino 300-series 2008 - 2012 Angled mount
How to remove speed limiter - Brodit ProClip for Hino 300-series 2008 - 2012 Angled mount
How do I remove the speed limiter
You cannot, it is programmed into the computer. You would have to get a modified chip or an EEPROM programmer.
Aug 04, 2015 | Cars & Trucks
If you don't live in California you can buy a tuner from SCT,Superchips or most other brands that will raise your speedlimiter
Aug 19, 2014 | 2007 E250
Remove speed limiter
Most cars can have the speed limiter removed from dealer OBD scan tools or third party scanners like SnapOn or OTC etc... you can also remove limiter if your car has a custom programmer made for it for performance mods.
Jul 07, 2014 | Vehicle Parts & Accessories
Need to remove speed limiter from 2003 hyundai elantra, 5 sp thank you, jim
you cant remove the speed limiter it is software in the computer and cannot be deactivated
May 18, 2010 | Hyundai Motor 2003 Elantra
Speed limiter
you must either have a speed shop re-flash your computer, or purchase a programmer that plugs into the obd2 port; removing the limiter is at your fingertips! hope this helps.
Mar 02, 2010 | 2002 Chevrolet Silverado 1500
How do I remove the speed limiters from a Suzuki Quadsport Z50? The manual mentions a maximum speed reduction spacer that can be removed, but the picture is intentionally obscure so that you have to take...
Speed limiters are usually just a block or shim in the carburetor throttle tube, take the cap (top) off and remove, careful not to bend the needle, and replace.
Sep 06, 2009 | 2003 Suzuki TL 1000 R
Removing a speed limiter from a vauxhall combo cdti van
The speed-limiter is likely to be enabled via the ECU. Removing the limiter is a five-minute job if you have access to the GM Tech 2 electronic management/diagnostic tool.
If the van is yours then there's no legal requirement for the limiter. You could just book it in at a Vauxhall dealer for the limiter to be removed. They may charge you for an hour's labour though. Still worth doing in my opinion.
Jan 25, 2009 | 2005 GMC Sierra
Speed limiter
It's programmed into the ECU - there's nothing you can remove from the car to delete it. You'd have to find someone who can reprogram your car's computer with the speed limiter removed.
Aug 04, 2008 | 1998 Cadillac Eldorado
Top speed limiter
you have to a speed cut defender and get it installed you can get these from hks.
Jun 09, 2008 | 1994 Toyota Corolla
Brodit ProClip for Hino 300-series 2008 - 2012 Angled mount Logo
Top Brodit GPS Experts
Gilbert Ruiz
Ted Maxwell
Mike Charette
Are you a Brodit GPS Expert? Answer questions, earn points and help others
