Question about Hitachi 46F510 46" Projection HDTV
Model 46f500 Is there a protective plastic cover that can come off the screen so there is no glare?
S.N RS051DL103300. I just want to know if you sell a protective screen that is anti glare?
Anon. Protective screen that is anti glare, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
NuShield Anti glare Films In TV Room Design
FAQ Answers for Questions on our TV Screen Protectors
TV Screen Covers ScreenProtek
How to rid your HDTV of reflections
May 26, 2016 | Televison & Video
I have the newest version of this plsma TV. It is one month old. I tried to clean some areas of the screen with a micro fiber cloth and a dab of windex in 1 corner of the cloth, not realizing that the...
You have damaged the outer protective screen. Only replacement will fix. Water only on a damp cloth should be used to clean. However, the outer screen can be changed. Since the tv is almost new you will have to contact Samsung at www.samsungparts.com through customer service at 1-800-627-4368 9AM to 8:30PM Eastern time. When changing the outer screen be sure to never touch the inner screen after removal. You have to take the back off the set to get to the screws holding the baziel or "plastic frame" to remove the outer screen. I have never taken a screen off of a set that new so I advise you exercise patience when removing. Have the product code ready for customer service to locate the proper protective screen. And serial number.
Oct 23, 2011 | Samsung PN64D7000 3D Plasma TV
I want to reduce the amount of glare on my screen but i cannot and im struggling with the glare
Buy a anti-glare privacy screen. (Privacy monitor filter)
It's the best way. They should be available at any computer store.
It is thin like a plastic cover that you place on your screen.
Sep 17, 2010 | Compaq Evo N620c Notebook
Where can I get a replacement plactic screen cover
This set has 3 screens---the outer one is really only for glare--clear plexigalss--no longer available from Sony.
Sony 4-070-602-01
SCREEN, FRESNEL Sony 4-064-343-11
SCREEN, LENTICULAR Sony 4-058-894-11
SCREEN, PROTECTION (CONTRAST)Outer one is (Contrast) the other two inner ones are showing as available and about 180 each.
You would have to either have someone dismantle or do it yourself---most of these sets you have to remove all three screens from the rear of the set---then remove the outer contrast one if it is scratched or cracked--
If you get it out and measure it: It is possible you may be able to find a company who can cut you a plexi-glass piece to replace it with--lots of work to do this and you have to use extreme care when you remove the two inner screens--easy to damage them---Usually the inner two are taped along all the edges to keep dust etc from getting between them and the front one is a short distance forward of them.
The front protective screen is really only there for glare and to protect the inner screens from damage---I have seen people who had a cracked outer one just dismantle and remove that one---put the others back and use the set that way---have to be careful as the inner screens are easy to scratch or damage with the outer one removed.
Also---I have seen several where someone removed the outer one and got a piece of plexi glass big enough to put on the outside of the front of the set---secured all around the edges with velcro--does not look as good as the original but prevents glare and protects the inner screens.
If this told you something you did not know or helped you rate this solution as I do this here for free.
SD TECH
Jan 03, 2010 | Sony KP-53V80 53" Rear Projection...
Glare-can we remove plasting sheeting on screen?
yes, you need a philips screwdriver, pull the speaker grill off, remove the 4 or 5 screws along the bottom of the screen assembly, unlock the 2 electrical plugs and remove them from their ties, lift up on the screen assembly and remove it. turn it upside down and remove the 4 screws holding the bottom of the frame on, remove frame bottom, slide screen protector out, re-assemble, bingo, no glare.
Sep 08, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Screen reflection and glare
you can buy a protective anti-glare screen that covers the tv screen
Jul 09, 2009 | Televison & Video
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Sharp 61R WP4h
side fade is down side of projection tv's
there is no harm other than you have to be careful now.
Dec 04, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT53wx53g Rear Projection TV screen cracked
You can try it, but through my experience, it just does not look good. You may not have a problem with it. Give it a shot. Good Luck.
Oct 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Hitachi 46F510 46" Projection HDTV Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
