Question about Projection Televisions
JVC I'Art Pro, Color Fade
Color fades in and out...but now, it is a constant blu/green. Everything else on the tv works fine. Tv is about 4 years old. My kids did play some Hi-res games i.e. Playstation 2/3. Hope this helps.
Thanks for any help,
  • 13 Answers
SOURCE: JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Posted on Dec 27, 2007
0 characters
1 Points
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
Color blinkig in and out.
It seems like the color wheel might start to fail.
Do you hear any abnormal sound(s) from the TV when ramdon color appears.
Would you be able to check and make sure all the fans are working properly?
Jul 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Green shadows all over the screen
You didn't say how old the set was and how much it's used, but the shadows you're describing sound like a bad green picture tube.
Hope that helps...
Apr 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Projection Televisions
Picture and Sound fade in an out
4 years? Sounds like the lamp compartment is overheating. Take the covers off the right side (To Access the lamp) and the whole panel on back. This will give you access to the lamp assembly and fans. Get a can compressed air and blow everything out. Try to blow everything towards the right side and pull the lamp and do it seperatly.
Sep 09, 2007 | LG RU-52SZ51D 52" Rear Projection...
Projection Televisions Logo
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
