Question about Daewoo Dryers
How to take apart a daewoo front load dryer to change the rollers?
5 Suggested Answers
  • 146 Answers
SOURCE: front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Posted on Dec 22, 2007
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
ginko
  • 19396 Answers
SOURCE: Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 06, 2009
machinetech7
  • 1344 Answers
SOURCE: Maytag Neptune front loading electric dryer
Check the blower wheel, A lot of time the blower wheel gets bored out where it connects to the motor shaft and basically just knocks around. A good test is to start the dryer, wait for the rumbling to begin then open the door. If the blower wheel indeed is the problem, the sound will continue for a brief moment after the door opens. I posted a link below to help, hope its close since I didn't have a model number. #15 is what your looking for in your machine.
http://www.partselect.com/ModelFrames.aspx?ModelID=128410&ModelNum=MDG6700AWW&mfgModelNum=&ManufactureID=1&Selected=58665&Position=4&mfg=Maytag&Type=&Mark=4
Posted on Jun 23, 2012
I have a daewoo dwr-we3011rr dryer and want to be sure my heating element is bad and not another issue. dryer turns on and tumbles fine but has no heat.
Try to find someone who has an ohm-meter or a multi-meter and can take your machine apart and test the heating element. One that is working should show continuity through the element., One with a blown element should show no current flow through the element.
Be blessed.
Sep 23, 2013 | Daewoo Dwrwe3011ww Dwrwe3011ww Front Load...
Is there a procedure to change belt? Also 1 (left) drm roller
No set procedure. Idler wheel is a common failure on Amana Dryers. Remove front panel and front bulkhead, from there you can remove belt from idler and pull drum from unit. The screws are a 5/16" hex head. While you have the unit taken apart, ensure you vacuum the interior cabinet and make sure your vent out of the house is clean, this will help prevent a house fire.
Mar 28, 2010 | Amana ALG331RAW Gas Dryer
I have a Kenmore Stacked washer/dryer that was given to me. The dryer has a pretty loud sqweek. Is this normal?
A loud squeek is normally caused by the tension pully or the rear drum rollers seizing. Remove the two screws holding the inspection panel between the washer and the dryer. Remove the panel. Slide a 1/2 inch paint scraper between the top and the cabnet front and releave the spring loaded clips that hold the top on and remove the top. Loosen the two screws at the bottom of the dryer front panel. Looking down inside the front panel remove the two screws holding the front panel to the cabnet. Mark and remove the wires going to the door switch and remove the front panel. At the rear of the dryer remove the inspection plate at the bottom of the dryer and remove the belt from the spring loaded tension pulley. Go the the front of the dryer and remove the dryer drum and belt. Now you can check to see if the rollers are worn or seized and check to see if the tension pulley is seized.
Purches a kit that includes a new belt, drum rollers and tension pulley and replace all. Reassemble the dryer in the reverse as to how you took it apart.
Jan 30, 2010 | Washing Machines
How do i get my dryer apart
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 27, 2009 | Maytag Dryers
My maytag dryer makes an obscene rumbling noise every 10 seconds. It's still running and the heat works, but it sounds like it is about to shake itself apart.
I have not heard it call obscene but your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 07, 2009 | Maytag Dryers
We are trying to replace the belt to our front loader dryer DLE5977W and are not sure how to take the dryer apart. Do we start from the front or the back.What steps do we need to replace the belt. Thank...
If it is a front loading machine:
You would remove the front of the machine, that will expose the drum and belt, remove the drum and belt and that will expose the drum rollers,motor, idler arm pulley.
Before you replace the drum and belt assembly, Check you drum rollers for flat spots, If they have flat spots on them replace them. I would also recommend that you lubricate your drum rollers with a good quality of machine oil such as 3 in One Oil. This will save you later on another disassembly because of noisy drum rollers.Apply the oil at the shaft of the drum rollers.
I hope this helps
Oct 04, 2009 | Dryers
I need to replace roller's on LG Tromm Gas front load dryer
There are 4 screws holding on a plate on the back. It is not the whole panel. Are you trying to get at the ball sensor?
Feb 24, 2009 | LG WM-2277HW Front Load Washer
Kenmore Dryer Drum is very loose and noisy.
It sounds like one of the rollers has a bad bearing. You will need to take the front off the dryer, unhook the belt, and remove the drum to check the rollers.
Nov 20, 2008 | AEG T57800 Electric Dryer
Continuous Squealing
take the dryer apart and oil the drum support rollers and the idler pulley. If this does not fix it. Replace the support rollers and the idler pulley. To acces the rollers, take the 2 screws out under the lint filter and then raise the top of the dryer. then remove the 2 screws holding on the front. Take the front off and remove the drum and theres the rollers and the idler pulley. (taking apart the dryer applies to a whirlpool, kenmore, roper, kitchenaid, estate.) If you have another brand let me know i will tell you how to take it apart. (if oiling doesnt fix it your local parts store should have all the parts needed in stock.)
Nov 15, 2008 | Whirlpool LER4634J Electric Dryer
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
221 people viewed this question
Top Daewoo Dryers Experts
Andrew Taylor
Andrew Taylor
David Ellis Rhea
Mai Lor
Are you a Daewoo Dryer Expert? Answer questions, earn points and help others
