Question about Garden
Troy built lawn tractor gtx 2446 cutting deck pulley and spring placement
rockitman187
  • 2559 Answers
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Posted on Apr 04, 2009
  • 1114 Answers
SOURCE: why would my troy buit lawn tractor sputter and
The tractor is bogging down under load, which can be due to a dirty carburetor or carb out of adjustment or it may just need a general tune up. Before you start tearing things apart, try some carb cleaner poured in the gas tank, and spray some carb cleaner down throat of carb. Check air cleaner and spark plug. Spray all linkages, connecting points, etc on the carb and engine to clean away any gunk.
Posted on Jul 23, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Posted on Aug 26, 2009
  • 89 Answers
SOURCE: I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Posted on Nov 09, 2009
mickey813
  • 472 Answers
SOURCE: Need belt routing for mower
go to parts tree .com find your brand put in the model number and it will show it to you
Posted on Sep 02, 2010
I need to know the placement of the deck belt on my husqvarna mower 26k54t. I think I keep twisting it the wrong way, which pulleys need the flat side of the belt on?
https://www.partstree.com/parts/husqvarna/mowers-lawn-garden-tractor/gth-26k54t-96043001101-husqvarna-garden-tractor-2006-03/mower-deck/
Sep 09, 2016 | Husqvarna Garden
How to reinsta l idler pulley arm
Commercial Mower Maintenance-Replacing Idler Pulley ...
? 3:44
www.youtube.com/watch?v=io2aCjM0o8Y
Sep 30, 2011 - Uploaded by askanthonynow
After new bearings were placed into an idler pulley, it is being installed on the deck of the mower. This is the .
How to Replace the Deck Idler Pulley on a Troy-Bilt Pony ...? 8:04www.youtube.com/watch?v=HY9AuNe5DWAAug 13, 2013 - Uploaded by eReplacementParts.comThis tutorial will show you how to remove and install the idler(4.25") pulley on a Troy-Bilt Pony lawn tractor/riding mower. Helpful items include ...How to Fix the Idler Spring on a Zero-Turn Mower ' Home ...
Nov 01, 2015 | Yard Machines Garden
Trying to change the drive belt on a GTX 2446 Troy Bilt garden lawn mower rider can't get the pulley upper plate of the motor
You must remove the electric PTO clutch in order to remove the motion drive belt. Also it probably require you remove the bolts holding transmission if your going and secondary drive so can it off and on.
Aug 09, 2014 | Garden
Craftsman Lawn Tractor runs but does not cut grass?
Above deck, below tractor is black cable which has spring on end and goes to a tensioner pulley.
This cable should be locked into a bracket with a retainer pin and then its spring tip (rounded) goes around the top of tensioner pulley axle then a small washer on top and then retainer pin goes through this tensioner pulley axel shaft tip to hold spring onto it.
Jun 13, 2013 | Craftsman Garden
I have a troy bilt GTX 2446 garden tractor, it will not crank. The battery in good. What is the problem?
If battery is good, then check all safety switches and check starter. If the starter is trying to turn the engine and the engine is an OHV engine you need to also check the intake and exhaust gaps, go the smalleng.com and you can see how to do this if you need to. Good Luck...
Sep 07, 2011 | Troy Garden
Change blades on a lawn tractor pony? troy built
just jack it up so you can get under the deck and unscrew the bolt on center of ech blade take note on how the curves of blade are angled do one at a time incase you forget but bolt back up tight and you are ready to cut if you try to resharpen the blades make sure you balance them or they will mess up the deck bearings
Nov 02, 2010 | Troy Garden
I have a troy-bilt gtx 2446,i put a new drive belt on ( the long one ) Now when you are in a gear the brake will not stop the mower.i have tried to adjust the linkage on the idler pulley and also the brake...
If you don't have your manual, this might be for yours (you didn't list complete model number)
http://www.managemylife.com/mmh/owner_manuals/10259/TROYBILT-Lawn,-Tractor-L0401081?brand_name_search=14AZ809H063+TROYBILT
See the part about changing drive belt and adjusting. If you got it around idler pulleys wrong, it might not lelt the clutch go far enough to apply the break.
Jul 28, 2010 | Troy Garden
I have a 19 hp Troy Bilt Super Bronco with the
sounds like spring tension on top of deck is connected to a bolt post,mine broke and went missing with the spring,blades kept slipping,didnt know how to tighten belt,go figure
May 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Nov 09, 2009 | Garden
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
