Question about Samsung HW-E350 Crystal Surround Air Track - Audio - HW-E350/ZA
No power try to switch on but no power
When pressing the remote's 'on' button tv won't come on
does it power on using the power switch on the tv itself instead of the remote? if same thing happens when pressing the power on switch on the tv directly, try to test it on another power outlet. if it is connected through a surge protector or avr, see if connecting it directly through the outlet works.
try to also check if the power on switch of the tv is somehow stuck which may cause it to try to cycle on and off and same thing on the remotes on/off button.
now if this is specific to the use of a remote, replacing the battery might help.
Mar 09, 2014 | LG 60PK550 TV
Driver side window stopped working
most of the time driver side windows switch be the first switch to wear out.try removing window switch work switch while moving the wires see if window try to go up, if yes, window switch broken.if switch not broken check see if power going to window motor when you work the switch you need a test light or digital volt meter to check to see if power going to power window motor.if power going to power window motor, either window binding or power window motor faulty. make sure driver side window master switch not locked out.if no make sure all the other power windows work if not you have blowed fuse.
Nov 26, 2012 | Hyundai XG350 Cars & Trucks
My Laptop doesnot power up
Remove battery and power code. Press power buttom for few seconds. Connect ONLY Power code and try to switch it On. If it is not switching On remove power code connect battery and try to switch it on. If any of the above works let me know.
May 19, 2011 | Sony VAIO FX240 Notebook
We have the Samsung ShuttleX PC and it won't power on. Nothing on the computer is showing signs of power. We tried switching power sources, but nothing. No lights, no sounds...nothing. : ( Can you...
Try jumping CAREFULLY the to pins of the power button for an instant to power up the PC to see is the switch is bad or use other PC switch, Or you can get a Power Supply Tester.
Nov 26, 2010 | Shuttle XPC SK22G2 Barebone
I have a T5026 EMachine won't power up. Green light on motherboard is on , could it be the switch , tried putting a new power supply box in it.
to see if the power swithc is the problem-
first, try to isolate the wire that connects the power switch to the motherboard. once you have deternined where the power switch plugs, then remove the wires from the motherboard leads and try to short the leads by connecting them with a metal device like a screwdriver tip. if the switch is broken, it will boot when shorted with the screwdriver. if it still will not boot, then you probably need either a new motherboard or a new cpu.
Nov 06, 2010 | E-Machines Emachine T5026 power supply **...
Hi, I've got a PC which last time can't swich on. After pressing power button hundreds of times, finally boot up and working fine, but after I switch off can not start up again. The power button sounds...
do you know how to turn on your pc just shorting inside the motherboard???
try that if it works.. it means your button is the problem if not..
your power supply is the problem..
hope it's a help..
rate this plz..
Feb 06, 2010 | Office Equipment & Supplies
Fujitsu Siemens Scaleo 600. No power to processor.
Probably a PSU failure, although it could just be your power switch. Try shorting the power switch connections on the motherboard, if that doesn't work, replace the PSU with a standard ATX PSU. They're relatively cheap.
Oct 06, 2009 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
System not booting from power on switch
It seems the power switch is at fault you can try to use the reset switches cable for now and switch on the PC with the reset switch.
Jun 23, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Heater blower switch does not work.the switch is new also the resister is new .fuses on side panel check ok.what do I do next
Do you have power to the switch? Do you have power to the fuses? They may not be blown but they may also not have power. Not a likely scenario but possible. First look for power to the switch. No power trace to fuses. Next check if switch is getting power doe switch send power. Does blower motor receive power after you verified that switch has power. Is the switch from the dealer or a/m? Try these things first. If the switch is used than the switch is probably bad. Also there is a resistor on the blower motor that can go bad and that could be the problem.
Jul 29, 2008 | Chevrolet Silverado 1500 Cars & Trucks
Samsung HW-E350 Crystal Surround Air Track - Audio - HW-E350/ZA Logo
18 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
