Question about Lefroy Brooks Bath Waste Trap for Exposed Fitting Complete with 500mm Exten
My master bathtub is leaking
I have taken apart the faucet and re-taped the threads, that's not the problem. I checked all the vavles where the cold and hot water meet, nothing leaking there. I checked the shower faucet and that is not leaking either. I can see the pipes from my basement and it appears that the waste return pipe is the culprit. I took the waste plate off and noticed the pipe that connects to the tub has a rubber gasket around it but no putty or silicone to seal the connection. I adjusted the fitting and closed everything back up and that seemed to solve the problem but the leak is back. There is a short metal piece that fits on the inside of the tub and screws into the pipe on the outside of the tub to hold the pipe in place, one of the screw holes is stripped. Could this be my problem, I have never known a waste return pipe to leak. Should I putty the connection and silicone the threads to ensure a good seal? I have run the shower for twenty minutes at all temp ranges and the pipes dont leak, it only leaks when someone is taking a shower. Could our weight be causing the pipe to move behind the wall causing the leak? Please help, I really dont want to pay a plumber to rip out a wall, my house is less than a year old!
  • lucasbryan Jun 24, 2009
    Thanks Smartr10U,
    After some work, I think the leak is coming from the drain pipe, not the waste return. Should I go ahead and replace the whole drain assembly or try to putty the connections? The drain itself does not appear to be leaking so I think I may have a faulty hookup. I did a thorough visual inspection of the pipes and none have a crack that would be causing the leak. Thoughts, suggestions and advice would be appreciated.
    Bryan.
  • 1,305 Answers
Yes the weight of someone in the tub plus the water can push the tub down far enough to cause the leak.
Unscrew the flange in the tub that holds the drain to the tub. Get some plumbers putty and make a bead to fit between the tub and flange.
Make sure the rubber gasket is clean ..use a bit of plumber's putty on this as well. Get an assistant to stand in the tub while you snug things up.
Snug it up tight.... replace if the threads are stripped as you said.
Plus if your house is less than a year old, I'd talk to the contractor/builder if possible about warranty work...most reputable builders will cover their work for the first year.
Posted on Jun 22, 2009
  • KEN LaPOINT
    KEN LaPOINT Jun 24, 2009
    Bryan,
    Sounds like you're making progress! The typical compression-type connections that have the rubber or plastic rings under a large nut on the pipe are common leak spots.
    I recommend purchasing a small bottle of pipe thread sealant..comes in a small bottle or can with an application brush built into the cap. Back the compression nuts off to gain access to the compression rings and coat the flange and pipe in the area where those comp rings will be tightened down. Then slide the ring back in place and snug the nuts back up... The pipe thread goop will seal up any imperfections in the joint. After it's tight, take a rag and wipe off the excess and check for leaks...
    This has solved alot of leaks for me.
    Let me know if this solves it.
    Ken
Why is my Moen universal shower faucet leaking at the union
It sounds like you know what you're doing, but if it has O'rings, try replacing those. If there is a snug fix with the valve then the leak is a problem with the inner workings of the cartridge.
Nov 23, 2015 | Moen & One Handle Tub & Shower Faucet
I need to replace the hot water handle
A picture, model, or brand of the type of faucet you have will be helpful as there are only three types of faucets. One hole, two hole, and three hole faucets. The one hole ones have two types: a single hot or cold, or a mixer valve to combine hot and cold into a single faucet. Each have a surface mount or wall mount version.
They all follow the same similar installation method. Turn off water supply. Unscrew supply lines from supply to underside of the faucet. a Plumber's wrench is needed or a spanning crescent wrench to remove the supply lines.
-Unscrew whole assemble from the sink.
-insert new one into the same hole as old one.
-from underneath, install the new faucet using the supplied hardware.
-Use plumbers tape (Teflon tape). It's often a white or pink silicon tape around the threads prior to screwing the supply lines back in. Re-connect the supply line.
-Open hot water faucet to maximum. Slowly turn on the water supply. Watch for leaks and drips. If any close the water supply and undo the supply leads and apply more Teflon tape.
- to apply tape. Start at the end and pull tightly, wind the tape into the threads in the direction of the turn. Do not wind in opposite direction.
-Try to turn on water again, turn slowly until it is at maximum, watch for leaks and drips.
-now slowly close the faucet and continue watching for leaks and drops.
If the faucet is fully closed and there is no leaks, you've done a good job... basic plumbing 101.
Now if your pipes are solder types and not screwed in supply line, and you're not confident with a torch or have little experience, ask for help from a friend who has some torch knowledge or hire a plumber. It is simple to do but requires a lot more steps than simply screwing in and unscrewing supply lines.
Aug 30, 2015 | Plumbing
My house is only 2 years old and has begun making a "hammering" noise when I turn on the cold water tap in the bathroom only. The water will actually stop flowing in a moment or two.
If the water actually stops running it might be a problem in the internal balancing valves. Some valves will restrict flows of the other water-supply: If there is slow hot water it throttles the cold water, if there is slow cold water it throttles the hot water. It is meant to stop the screaming in the shower if a toilet for example is flushed and the cold water pressure drops. Some but not all valves can be taken apart and cleaned. Turn off both shut off vavles first!
Oct 18, 2013 | Hansgrohe 06649860 Solaris Single Hole...
New 352658 shower faucet drips
They are bad about leaking,you prob. need to replace the cartridge with new one. the seals in them get dry and shrink of they have been sitting in the box for a long time on the shelf or in a warehouse. you never know how long ago they were built and just sitting.
Nov 27, 2012 | American Standard 2083.102 Standard...
Sprayer hose leaks at the base of the faucet after sprayer replacement and thread tape application
Make sure the internal washer is intact and there is no damage to the parts that you are connecting together. Also, do not use too much tape....one or two winds is enough and wind in in the direction of the action of the female connector (clockwise) so you don't bunch it up in one spot.
May 05, 2012 | Plumbing
Cold water faucet drip. Took apart fausect, no visible sign of wear. Faucet is only seven years old. Does faucet have a basin washer that may be worn ?
Hi bobwiz...
Your faucet may be leaking because of a bad seat that the rubber/plastic washer seals on...
Check the seat condition for wear, especially a "line cut" in the brass seat from where the water has eroaded the seat, this could cause your leak.
If the seat has a "line" cut in it, then you will need to purchase a seat repair tool from your local hardware store and refinish the seat.
Check and replace your plastic/rubber washer, it is 7 yrs old and maybe hard and not seating properly.
Please take time to rate me
Aug 17, 2011 | Delta Home
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
I have a moen fawcett. single knob, it is leaking
the spout is the end piece where the water comes out. where is it leaking ?.
when you put it back together i would suggest you use some teflon tape often called plumbers tape on all the theaded fittings as that will prevent any leaks as well.
Nov 27, 2009 | Moen & One Handle Tub & Shower Faucet
Lefroy Brooks Bath Waste Trap for Exposed Fitting Complete with 500mm Exten Logo
428 people viewed this question
Top Lefroy Brooks Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Lefroy Brooks Plumbing Expert? Answer questions, earn points and help others
