Question about Cameras
AIPTEK HD 720DBOUGHT NEW IN TENERIFE BUT EVERY TIME I TRY TO TAKE AFILM IT TELLS ME IT IS FULL WHEN EVERTHING IS DELETED
  • 1 more comment
  • adburt8 Jun 22, 2009
    can not find the menue to delete card
    the camera give the same response without the card in
    it is no good the camera is not responding to anything i do
  • 13,433 Answers
Look for Format option in the camera and format the card, after that is done try taking a picture again.
Posted on Jun 22, 2009
  • Ekse Jun 22, 2009
    also make sure you have inserted a memory card and that the small switch one the card is not on the locked position.
  • Ekse Jun 22, 2009
    does your camera have a removeable battery? if so, take the battery out for 5 minutes and then turn the camera on again and try doing what I said.
  • 495 Answers
The problem Probably is that the memory card isn't the right kind, so it just records to the "Built in memory". The only way to fix this is to format the Memory card.
And you might try searching for the firmware update aswell.
  • 744 Answers
Hi..
Your camera is not communicating with your card. With the card in the camera, you need to go into the Menu and find Format the Card. This procedure will delete the pictures from the card and set it to communicate with your camera. After formatting is complete, (card inside the camera) your camera will say....No images. This means that the card is clean and you can start taking/recording pics again. Hope I was able to explain formatting in a little more detail for you...
this will fix ur problem for sure..
Can Aiptek A-HD 720P record footage from old games?
the A-Hd is the only Hi def camcorder of Aiptek to record into the camera the Av input iti s called. the A-hd has a lower gain of the mic meaning all video recording of the actual live footage will be low on older models possably normal on the newer today
the Go-hd does not record any footage into thecamera no AV input it will have a higher gain meaning the sound going into the camera will be too loud there is no medium level
Apr 21, 2017 | Aiptek A-HD 720P Flash Media Camcorder
Memory full aiptek pencam trio
Hi, i got exactly the same problem with my Aiptek Trio Pencam HD, and i solved it !!! :D
I opened it, you got to remove 6 screws:
2 screws at the bottom, 2 screws on the side, remove the plastic clip, remove the plastic cover over the cam, it is fixed with adhesive, and remove the last 2 screw.
Now open your cam, now you can see the electric circuit of the cam, and on this electric circuit you can see another little circuit with a chip, it is cliped, mine wasn't cliped correctly, try to clip it, and be sure that doesn't move.
PS: Sorry for my bad english
Mar 16, 2012 | Aiptek PenCam Trio HD Black Camcorder
When I power up my Aiptek 720P camcorder the screen tells me the memory is full although I have emptied the memory
Try reformatting the media, if using an SD card, replace it with another and use a PC and format it FAT16 with a PC and USB dongle return it to the unit it should be OK, you may have to format again after you put it in sometimes too.
Oct 06, 2011 | Aiptek A-HD 720P Flash Media Camcorder
Deleting files on HD720p Aiptek camcorder
You are not doing anything wrong. For some reason, Aiptek doesn't give you this option on the camera. You have to insert you SD card into a reader and delete it that way. Ya, I know, doesn't make sense. Also, a feature I hate is it does place your videos into one continuous file. Only video clips, so each time you stop then start recording, it creates a new file. Anyway, I've had my Aiptek since 10/2008 and no problems so far. Great indoor videos. Not too crazy about the still pictures though.
Dec 08, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Iwant the driver
Hi, the first site seems to have a one fits all aiptek driver. The second aipteks home, suggests that you shouldn't need one as it is plug and play. Have you deleted files you shouldn't from the camera? http://www.opendrivers.com/company/2185/aiptek-free-driver-download.html http://www.aiptek.com/drivers/actionhd/
Jul 01, 2009 | Aiptek A-HD 720P Flash Media Camcorder
A-HD 720 P CAMCORDER MEMORY FULL 18 SECONDS THAT IT
I had same problem. The camera was defective. I had to ship it back to Aiptek for repair. It was only using internal memory, and not recognizing the SD card.
Feb 07, 2009 | Aiptek A-HD 720P Flash Media Camcorder
Memory full though there is no data
did you get it off ebay of oversease county?
Jul 09, 2008 | Aiptek PocketCam DV4500 Digital Camera
Aiptek IS DV2
Seems like its time to flush the contents of the memory card of camcorder to a computer.
There's a limited amount of memory in every memory card. After constant recording, the memory  gets full and the recorded stuff needs to be either deleted or flushed (uploaded to a computer) to make room for newly recorded stuff.
Unless you have a blank memory card, your problem should be solved by the above mentioned idea.
Oct 20, 2007 | Aiptek IS-DV2 Camcorder
Cameras Logo
51 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
