Question about Nikon Cameras
Red exclamation mark when I turn on Coolpix aw110 camera, then it shuts off. how do I get my camera working again?
mattozan
  • 555 Answers
SOURCE: nikon coolpix s200 lens-message says
What kind of lense do you have attached? Does it give this error with other lenses?
Posted on Jun 04, 2008
SOURCE: have fujifilm finepix f40fd. protected card shows. wont clear
I had the same problem with a Fufifilm camera. When I looked closely at the memory card I noticed a little white sliding button on the left hand side. When it is in the down position the card is locked or protected. Just slide the button up and put it back in your camera and it should work.
Posted on Dec 06, 2008
  • 11967 Answers
SOURCE: When I turn the camera on there is an exclamation
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 23, 2010
SOURCE: When turning camera on get
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s3200s4000series_manual_01.pdf
there is the Manuel, the error is most likely from the motherboard of the camera getting damaged in some way, sand, water, etc. best way is to let the camera sit in a bowl of white rice dehydrated of course to dry any possible water. if the problem persists go to your nearest electronic store and ask them to have a look at it.
Posted on Jun 14, 2011
Rider On Way
  • 1679 Answers
SOURCE: Camera will not turn on, says turn off camera and turn on again, but does nothing else
Click on the link below to fix the Camera issue. This link will be helpful for you in future too
Troubleshoot Camera Issue
Regards,
Suhail
Posted on May 16, 2012
View screen won't come on.
hi,
even though this is a water proof cam, long time usage in water will cause to enter moisture or water particles in side, please open carefully clean the LCD strip and the terminal jig, motherboard etc with C R C liquid or similar things,re-fix it, will work normally.
Apr 17, 2015 | Nikon CoolPix AW110 Waterproof Digital...
Nikon coolpix troubleshooting
Not even what you are outside?
When you are in a building, it is normal for a GPS receiver that it can't make contact with enough GPS satellites, to calculate wrier it is. When you are outside and have a clear sky, it can take up to one or two minutes before the GPS receiver can work out where it is. But that is it. When your battery has not enough power, the camera also can switch of the GPS, to save power.
Jan 11, 2014 | Cameras
I think and it sounds like a hardware failure of the screen, have it serviced.
Nov 22, 2013 | Cameras
Just bought the Nikon S01 camera. Charged it completely, turned it on, completed setup, took a few pics. Then when I turned it off and back on, it says "Card is not formatted. Format card?" If I select...
Save the pictures you have taken to your computer, and then choose the Format Card option. You have to Format the Card to make your camera work. If this does not work, contact the Camera's company web site and ask them for advice
Sep 01, 2013 | Nikon Inc Nikon Coolpix S01 Silver
I have a nikon coolpix 5000 and i got some cf cards from a friend that have been formated in a pc and the camera dosen't see them how can i format so camera can use them
You will need to connect the phone with the one marked bluetooth once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually click start right
click on my computer you should see your mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll
through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
if your computer came with a motherboard disc the drivers could be on it
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps you
http://download.cnet.com/nikon-coolpix/3000-18489_4-66757.html
Nov 05, 2011 | Nikon Coolpix 5000 Digital Camera
Coolpix S50. Sometimes just won't work has a white screen with red exlamation mark and says lens error then a few hours later its fine again. Always seems to happen when I'm out in a club thought maybe it...
It sounds like there may be something blocking the lens from extending (internally. the S50 uses a zoom lens that retracts and extends sideways and a mirror to allow light through).
Aug 12, 2009 | Nikon Coolpix S50 Digital Camera
My camera "Nikon L10 coolpix" can't read by computer
Connect your camera to the USB and then right click on "My computer" icon and go to Properties --> Hardware --> Device Manager .. See if you have any yellow exclamations under USB devices .. If there are then uninstall the device by right clicking on yello exclamated icon and selecting uninstall .. then unplug the camera and reconnect again .. does that solve the issue??
Feb 26, 2009 | Nikon COOLPIX L10 Digital Camera
Cameras Logo
88 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
