Question about Toshiba DKT-3220-SD Corded Phone
How to set up night greeting
Need to set up night mode only
I have a Toshiba 3010DKT- SD. How do I change the greeting people get after hours when the phone is in "night"? Actually, how do I set up "night" mode?
Night greeting usually resides (and managed) in Mailbox 990 (Message #2). You'll need the passcode for that mailbox or your dealer will need to reset it.
Sep 19, 2014 | Toshiba DKT3010SD Corded Phone
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
Panasonic KX T7433 - I need to change the night mode message howevern when I select intercom 165 or intercom greeting and change the message I am unable to select the new message as the new night mode...
It's only that simple if you have a guide to what Custom Service or greeting plays now. When the system moves from Day to Night mode, the installer assigns a menu that plays. You can change it if you know which one. If you don't get the right one, there would be 98 other custom service and 31 other Company messages that you could record to and they'll never play.
Carl
Aug 23, 2011 | Panasonic KX-T7433B Corded Phone
I am trying to set a new greeting for our voicemail system for when our office is closed next week. I recorded what i want as greeting # 2, and when i go through the automated menu, i listened and the...
It sounds like what your calling greeting 2 is actually the night message (1 for day menu 2 for night menu)did you try calling with the night key on?
Dec 21, 2009 | Avaya Lucent Partner 616 Phone
Our Automated Attendant for our Norstar M7310 is picking up the wrong message. Where do we change that?
assigning messages is done by
feature 983>1020000>AA>Table>table 1>Greeting Type
depending on how you have the business hours times set it'll play the greeting you want. Typically I set the greeting type as morning:1, afternoon:1, Evening:1 and Non-business:4. then under business hours I set them up as mon- fri morn:0800am, aft:0800am, eve:0800am and nonb: 0500pm. sat and sun as morn:1200am, aft: 1200am, eve:1200am, and nonb: 1159am
press Rls when finished
that way when a caller calls between 8am and 4:59pm they get the day greeting and from 5pm to 7:59am they get the night greeting (greeting 4) saturday and sunday play the night greeting all day.
Dont forget to record greeting 4 as your night greeting.
Oct 14, 2009 | NorStar M7310 Corded Phone
Change night message
the night mode message that is being used is the main phone's (phone with lowest Ext. number) night mode message that was customized through it's voice mail.go on the main phone and listen to its voice mail. (voice mail ext. usually 165)continue listening until you hear some options.select the voicemail management optionthen select the change personal greeting optionthen select the after hours greeting optionhope this helps!
Feb 19, 2009 | Toshiba DKT-2010 Corded Phone
How to switch between day and night mode?
from the operators phone hit feature key dial 80.it should toggle between day and night.
Feb 09, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Night switching for KX-T7630
You have 4 different modes of calling available to be programmed: DAY NIGHT BREAK and LUNCH. Your installer has to set up the ICD groups, but you can create a LUNCH group which looks like the day mode but rings all phones. The codes are accessed by dialing on the intercom *780x where 0 is day 1 is night 2 is lunch and 3 is break.
You may use the NIGHT mode in the daytime, but if you have voice mail, it will play the night greeting instead of a day greeting.
Carl
Sep 09, 2008 | Panasonic KX-T7630 Corded Phone
Toshiba DKT-3220-SD Corded Phone Logo
Top Toshiba Lands Phones Experts
george  peters
george peters
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
