Question about Kenmore Dryers
500 ken more will not heat up
My dryer will no heat up when I turn it on put it still spins
  • Kenmore Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Posted on Mar 31, 2015
My kenmore 500 dryer heats even without pressing start and wont spin when is in on
may have 2 different issues here? bad timer stuck or burned out digital control board, and ur door switch or a broken belt may have gone bad for the not turning thingy
Aug 16, 2014 | Dryers
Kenmore dryer 500 series
Belt is worn or stretched or the right rear bearing is siezed. Change both if dryer is old.
Apr 24, 2014 | Dryers
My dryer does not turn on. I have power to the plug but the when I set the timer and then push the start button nothing happens (drum does not turn nor does it heat). The plug is fine and wires to the...
Hi Ken,
I recently wrote a short article about this for someone. I'll insert it here for you.
I would like to know what you found.
Best Regards,
Mark
Here it is.
When most Whirlpool dryers do not turn on at all. The most common cause of failure is the door switch and the door switch actuator.
Here is how you can test this.
1 Empty the dryer of clothes
2 Locate the door switch actuator. it will be over along the top edge of where the door closes, just inside the lip. There will be a little (3/8th inch wide) metal tab covered in plastic(or a plastic tab). This is the actuator that is mounted to the electrical door switch. The door switch is a valuable safety device that prevents children, pets and adults from loosing limbs and other things in a spinning dryer. DON'T BYPASS IT.
3 The tab may simply be broken off. If you can push the piece and hear a clicking sound, it means the switch is probably good but the tab is not.
4 To test this push the tab in or jam a ball point pen in there until it clicks, turn the dryer timer on and push the start button. It it comes on, that was the issue.
WARNING: NEVER, NEVER, NEVER PUT YOU ARM INTO A SPINNING OPEN DRYER DOOR.
JUST DON'T DO IT. IT CAN RUIN YOUR DAY.
5 If you push the tab and get no click but a sort of springy action. The switch is broken.
Usually the switch replacement kit has both the metal tab and the switch.
That is most often it.
If you can supply me with the model number of the dryer, I can help you locate the right part and give some instruction on how to do it.
Best,
Mark
Jan 24, 2011 | Whirlpool Dryers
Dryer will spin, but no heat
probably the heating element. Could be loose wire or bad element.
Feb 03, 2010 | Bosch Nexxt 500 Dryer
Turns on heats up but will not spin
more than likely you have a busted belt
Aug 23, 2009 | Kenmore 500 6952 Dryer
Dryers Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
