Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
How to get whirlpool imperial LA6800XTNO apart?
Washer leaking somewhere underneath the machine - hoses seem to be fine but water all over the floor. How do I take it apart to see what is going on?
3 Suggested Answers
  • 61 Answers
SOURCE: Oil and water leak
Chances are they are not related if the water is clean.These units can run quite a while dripping small amounts of oil. The drain hose is a possibility but there are other places it can leak from. Call a local tech he can run the machine with the cabinet removed and should be able to find the source of the water leak. good luck
Posted on Dec 19, 2008
jmgldsmth
  • 2005 Answers
SOURCE: leaking tub on whirlpool washer
replace the main (under tub) seal
Posted on May 04, 2009
My LG WM1814CW Washer is gushing water from underneath during every wash. We pulled the washer out and checked the hose lines and everything is fine there. What is underneath that could be leaking? Do we...
sorry about your floor! yes you need to pull it apart and see if anything looks funny-if no hoses are loose the tub may be leaking-this would be happening around the door seal-also try to wiggle the tub to check the tub bearing-which could also cause the leaking-if it seems to be loose this could be the problem also-cheers Denny
Oct 28, 2013 | Washing Machines
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
My whirlpool duet washer washe fine but water will leak down out on to the floor.
Plug off the mains socket. Remove the exit pipes, tilt the washer, you may find a hose underneath which has come loose or is damaged. Replace if damaged, or re-fit if come loose. Surely this washer is good. Before you remove the pipes, note where and how they are placed. Important.
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil and water leak
Dec 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer is leaking from underneath....
lean washer back against wall ck pump under front in center for leaks or dark gray area in pump face remove hoses remove clamp top and bottom of pump slide forward off shaft
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaks from underneath washer
my washer is leaking with water on floor.it is now geeting worse. the washer seems to clean fine. my floor is gettig ruined please help
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Whirlpool adg7540
check your hoses and your main water supply coming into the machine if the nut is loose tighten it up
Feb 17, 2008 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
