Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
I have a Raypak pool heater the pilot will lite but the unit will
Not ignite. I have good pressure checked filters all clean. .
My Rapak gas pool heater burner will not ignite. I changed the flame sensor and then the main gas valve (on a recommendation of a heating contracter) and after spending almost $300 on parts, I may have not needed, it still will not ignite. The water temp has been around 80 using the solar cover but now with the air temp in the 50's at night and only in the 70's in the day the water is a brisk 70 degrees. We would like run the heater now, so we can use the pool for a bit longer this fall.
Any ideas? Some people told me there is a valve that senses the proper amount of water is flowing around the boiler so it doesn't burn up, is this possiblely the problem that the valve is not opening?
Joe Snyder, Toledo, Ohio
Posted on Sep 09, 2009
Require millivoltage for gas valve on raypack pool heater
clean burn tube to pilot generator replace generator and make sure all wires tight
Apr 12, 2017 | RTO Pressure Switch 3902 Swimming Pool...
Raypak problem, Pilot is lit, can jump TH to TH to lite, goes out when jumper is removed.
check how many millivolts the pilot is generating. if pilot stay lit and burners wont fire u have a problem with one of the safties, lose wire connection, tstat control
May 28, 2013 | Raypak Pool & Spa
Raypak RP2100 Pool Heater
check gas pressure if too low this will happen
May 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pilot won't light
check gas pressure check safety circuit if ignitor lites check gas line to it maybe plugged
May 21, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gas ignitor bypass for raypak heater?
to test the pilot, you can use a torch to keep the sensor hot. if it still won't stay on, you have a bad flame sensor sometimes called either a thermopile or thermocouple. very easy to replace.
Mar 11, 2012 | Raypak RP2100 DIGITAL POOL HEATER R265
My raypak heater won't relight and the pilot is on
For the heater to burn, there must be water pressure and flow - and the heater must know of it. It is not enough that you know the pump is on, the heater must know it. Check your heater's water pressure switch.
What about the filter pressure ... high filter pressure would indicate need for a backwash. dirty filters slow the water flow. If your filter normally runs at 20 PSI (when clean) it should be backwashed at 30 PSI, rule of thumb = 10 psi over 'startup pressure'.
Your heaters job is to heat the water ... think of it as a very agressive bully. The water is absolutely necessary to keep the bully in check.
May 31, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Opened the pool for the season but can't get heater to start
the most common problem is pilot light. IF you have electronic ignition, check the electronic starter. You also need to be sure you are getting gas to the unit.
David.
May 25, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
462 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
