Question about GE GSD5620DBB Dishwasher
Drain valve and/or solenoid - GE GSD5620DBB Dishwasher
Will not drain, pump runs, how to unstop it
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jul 13, 2010 | Hotpoint 24 in. HDA3400G Built-in...
The dishwasher isn't draining. The unit was replaced and it still doesn't drain. The tubing leading to the garbage disposal is clear. The air gap seems to be located outside. What do I do, outside of...
Mar 28, 2010 | Kenmore Dishwashers
My bosch excell dishwasher won't drain it stops during the wash and won't restart until I have emptied the water then it will wash ok until it gets to the drain part of the programme then it stops again....
Mar 22, 2010 | Bosch Dishwashers
Dishwasher won't drain--Maytag Quiet Series 300
Mar 22, 2010 | Maytag MDB8751BWQ 24 in. Built-in...
Dishwasher will not drain
Mar 20, 2010 | GE Nautilus 24" Built-in Dishwasher
Water not draining totally
Mar 20, 2010 | Magic Chef Dishwashers
DIshwasher doesn't drain. 3-4 inches of water sits in the bottom
Sep 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Hi! You have not mention about mfg and model No.
Jan 15, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
GE GSD5620DBB Dishwasher Logo
18 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
