Question about Rocstor Storage Rocstor Rocpro 225 500 GB USB 20 Hard Drive
Noise coming from the rocstor drive - Rocstor Storage Rocstor Rocpro 225 500 GB USB 20 Hard Drive
Blue light is off and back up fails
The power-supply to the ROCSTOR is failing -- no power results in no light, and no access to the disk-drive.
Apr 19, 2015 | Rocstor Storage EAGLEROC E9 1 TB FireWire...
I use Rocstor amphibious-x7 but i forger password so ineed password reset way.. Please help me
These are probably one of the most secure devices around. I think you are out of luck. Try contacting Rocstor directly.
Nov 05, 2014 | Rocstor Amphibious X7 1 TB 2.5" External...
Need direction on how to transfer all my mac osx stuff to my rocstor..is this possible? If so how do I do this.
Use "Time Machine", which is part of OSX.
1] Connect your Rocstor drive to your Mac.
2] Open "System Preferences", and then click on "Time Machine" down in the "System" section of the System Preferences window.
3] In the newly opened window for "Time Machine" preferences, click on the "Select Disk" button to choose your Rocstor drive.
4] Click on the "Options" button to set any files/drives to exclude from backup.
The above is very basic directions for backing up to an external drive using Time Machine. You can get more detailed info through the Apple "Help" menu.
Hope this helps you!
Oct 10, 2013 | Teac HDU120/KIT 120 GB Hard Drive
I need Manual to rocpro 400-avk
try this one http://www.rocstor.com/support/downloads.html
Apr 17, 2011 | Rocstor Storage ROCPRO 400-AV (G102E801)...
Not recognized by computer. (Windows XP)
Try it on another computer. If it still does not work it has failed.
If the drive enclosure is the failure you should be able to remove the hard drive and install it inside your computer to recover the data. Good luck!
Apr 08, 2011 | Rocstor Storage Rocstor Rocport 4Cx - 2.5"...
... no drive motor sound
No drive motor means that either the motor is dead or the interface inside the case has failed. Take out the hard disk and put it directly in a desktop - if it fails even there then it's truly dead , junk it.
Mar 06, 2011 | Rocstor Storage Rocstor ROCPRO 400 AV 3.5"...
Rocstor external hard drive does not appear in my computer win xp although message it was installed when I connected the usb port
Good morning! first, make sure your external hard drive is properly connected to the USB port, then try to start / restart your computer again, automatically the computer should recognized the attached external HDD. best regards.
May 02, 2009 | Computers & Internet
Rocstor Storage Rocstor Rocpro 225 500 GB USB 20 Hard Drive Logo
26 people viewed this question
Top Rocstor Storage Computers & Internet Experts
Jax Planet
Jax Planet
Robbie Goodwin
James Gettemy
Are you a Rocstor Storage Computer and Internet Expert? Answer questions, earn points and help others
