Question about Vehicle Parts & Accessories
Fan belt on nison quest is squeking - Vehicle Parts & Accessories
  • 136 Answers
Belt's either too loose or needs replacing. Squeaking is generally caused by either looseness, or wear, causing the sides of the belt to loose frictional contact with the pulleys.
Posted on Aug 12, 2014
Just replaced high imit thermal fuse. The dryer belt squeks after 30 minutes on high manual mode. It seems the dryer is running much hotter than usual maybe causing the belt to squek. Any idea???
You may possibly have a bad temp control stuck on that caused the hi limit to open in the first place. That may be why you have a hotter than normal dryer. Temp controls are usually near the hi limit. A round disk with either 2 or sometime 4 wires hooked to it. Also check for a possible block vent keeping the hot air from venting outside.
Mar 20, 2015 | Dryers
Why my nissan quest heats up when i use the a/c ?
3 possible causes are....
1 Radiator clogged..replace
2 Water pump bad...replace (along with timing belt if it's time for one)
3 Bad electric fan motor ( or sensor that brings fan motor on ).
Jul 01, 2014 | 2001 Nissan Quest
Squeky belt on a 1997 plymouth voyager. The belt was replaced a month ago and started squeking again
Squeeking means slipping. Clean the4 pulleys and the belt with belt cleaner (Pep Boys). Adjust the belt to proper tension. Check that whatever the belt is driving is turning easily and does not have bad bearings.
Oct 15, 2013 | 1998 Plymouth Voyager
Hi I have a 307 xsi 2L 2002 I recently had timing belt/waterpump both changed and yesterday the fan belt but the car is now worse than before whining noise squeking when in idleing and driving accept in...
readjust the fan belt and check the condition of the pulleys The secondary air injector is showing a malfunction ---causes are ---wiring---AIR valve--- AIR sensor--- ECMI would be checking the wiring and connections as they may not have been replaced properly after the timing belt work. Replace with genuine units only as some after mark units are not compatible with the cpu.
May 27, 2013 | Cars & Trucks
Why would front squeek
could be a couple things fan b elt to tight or water pump or air cond compresser noisy .runing the motor lift the hood to check the squek will be realized
Feb 10, 2012 | Mitsubishi Cars & Trucks
Belts are ok but there is a lot of squeking is there something i can do to stop this
You can start by spraying the belts with Belt-lub which can be purchased at any auto parts store; the lub will also extend the life of the belts. Also check the adjustment to see if the belts need to be tightened.
Mar 17, 2011 | Chevrolet G10 Cars & Trucks
How do I change the Fan belts on a 2005 Nissan Quest?
ther is a tensioner use the rite size wrench 2 move the tensioner back. so u can take the belt off its one of the pulleys
Feb 17, 2010 | 2005 Nissan Quest
Squeking belts
take it back to the shop, they should do it for free. and it should only be the fan belt
Mar 07, 2009 | 2003 Honda Accord
2000 NISSAN QUEST
it is probably the idler pulley bearing coming apart from lack of lube (worn out).
go to this site for repair instructions
http://autos.groups.yahoo.com/group/villagerquest/
Dec 01, 2008 | 2000 Nissan Quest
Vehicle Parts & Accessories Logo
27 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
