Question about Brinks Locks & Locksmithing
Where can I get extra keys for my brinks lock?
Misplaced my spare key
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
PBREAK
SOURCE: brinks safe
OKAY! THIS IS WHAT MY INSTRUCTIONS TELL ME, HOPE THAT THIS HELPS! HERE YOU GO - TURN THE DIAL TO THE RIGHT PASSING THE 1st NUMBER 4 TIMES & STOPPING ON THE 1ST NUMBER THE NEXT TIME AROUND / TURN THE DIAL TO THE LEFT PASSING THE 2nd NUMBER 2 TIMES & STOPPING AR THAT NUMBER THE NEXT TIME SROUND / TURN THE DIAL TO THE RIGHT PASSING THE 3rd NUMBER THE NEXT TIME AROUND / TURN THE DIAL TO THE LEFT TO THE 4th NUMBER & STOP - NOW INSERT THE KEY IN THE CYLINDRICAL LOCK & TURN IT THE THE RIGHT TO OPEN.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: key won't turn, steering wheel locked, brakes locked.
With the key in the ignition, tap on the key with something heavy like a pair of pliers, screwdriver etc. It will cause the pin inside the mechanism to drop, and the iginition will turn. Happened to me today, worked like a charm.
Posted on Apr 20, 2009
  • 76 Answers
SOURCE: lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Apr 28, 2009
MECP Guy
  • 344 Answers
SOURCE: how to disable honda accord 1997 Immobilizer
I show immobilizers where only started in the 1998 accords, if you have a remote starter and they used a key in the box bypass all you need to do is find the box under the dash open it up and use the key
Posted on Jan 31, 2010
I need extra keys for Brinks Padlock key # M1 3514
take a sample and have a locksmith cut new keys
Oct 21, 2017 | Locks & Locksmithing
Need to order replacement key mine broke off i have number on key , its a brindk padlock stainless steel number m1 0916
If you have both pieces of the broken key, it can be duplicated.
I did not find that key code listed for Brinks, but perhaps you can get one from Brinks. A locksmith can make a key, check the cost. You really don't want to pay more than the cost of replacing the lock.
Jun 15, 2014 | Brinks Locks & Locksmithing
Why can i not get keys made for brinks brass padlocks
Do you mean duplicates of keys or do you have no working keys?
May 23, 2014 | Brinks Locks & Locksmithing
Why can i not get extra keys made for your padlocks?
I think a local locksmith would either be able to make the keys or give you a reason why keys can not be made for your locks. Look up 'locksmith' in your local yellow pages.
Can I get extra keys for padlock set, key # 02770
Any locksmith should be able to cut you replacement keys. I cannot verify it, but the key code is likely the actual cuts of the key, and so it will be easy to cut them. If not, the locksmith may have to use the code to look up the cuts, which may cost a bit more. Even then, it will still likely be cheaper than trying to have them mailed from the manufacturer.
Apr 10, 2014 | Brinks 1-9/16 In. Brass Long Shackle...
I have a Brinks padlock model TSA007 it has a keyhole but it didnt come with a key, can i purchase a key just for backup?
That key wont do anyting but allow TSA to open that lock. You cannot get that key because it is a master key that opens all those locks and it is restricted.
Jan 22, 2014 | Brinks TSA Resettable Padlock
I have a Brinks 5054 safe but no key
This lock is a pin tumbler lock and can be impressioned by a locksmith. If you can't find anyone in your area that has the blanks you can send the lock to A1-Locksmith and we will make you Brinks key's
Feb 14, 2010 | Sentry Fire-Safe Media File - SEN6720
Locks & Locksmithing Logo
24 people viewed this question
Top Brinks Locks & Locksmithing Experts
john h
andrewcahoon
Are you a Brinks Lock and Locksmithing Expert? Answer questions, earn points and help others
