Question about Scotsman Kitchen Appliances - Others
Thin ice cubes
When the ice cube call down they are all attached as one piece.how do i adjust so when it drops it drops as individual cubes
SOURCE: small ice cubes
The ice maker is time filled, it only has a certain time in which to fill. There is no way to adjust the water level. Check the pressure limiting valve which is in the water line before the filter. Have you replaced the filter? Remove the filter and pressure limiting valve and see if the ice maker receives more water. If it does, then replace the filter and check again. If it is still good, the pressure limiting valve is faulty.
Posted on Nov 03, 2007
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
farfield
  • 462 Answers
SOURCE: Ice Cubes won't drop
Something is holding your Ice Slab at the bottom from your description.
Some causes are
1 Dirty - scaled up evap, or just dirty w muddy covering,
2 the vacuum breaking holes are stopped up If it is making a sla whith the evaporator warm no ice take a flashlight and hold it where its shining to the back of the evap and look for the light on th cube forming slots next to the ones your shining the light into Upper corners of each hole must be open.
3 The slab is freezing uneve most like cause is a stopped up distributor tube at the top thats feeding the water down the evaporator.
4 On some models thay had a closer fitting water curtian (the cover in front of the slab) and the top of the sheet touched this and caused the slab to stay uprite and continue the "slide" forward.If your curtian is of the older style and has metal hooks on it with verticle slots n the curtian look at the slots and see if the slots are worn making the whole curtian slide down ward I have seen this several times.4B On some older models there is also a plactic coated wire diverter on the bottom infront of the evaporator. If the palstic coating is gone or the bottom or is not even, the slab could hang up there. 4C If you have the newer plastic pins make sure thay are seated in the mounting properly.
5 Nickel plating could be comming off (any copper color on the lower 1/3 of the evaporator?).
6 I have seen some of the horizontal plates them selves be loose and not in flush try pushing and pulling on them especially the ones at the bottom. ANy that are loose and comming out is your problem.
This lengthy extrapolation is by no means all of the possibilities but most of the common ones. If this helps you solve your proble please rate me accordingly. If it leads you to the correct and completed repair WOULDNT WE MAKE A TEAM?? And Good luck to you.
Posted on Mar 18, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
My scotsman ice machine makes thin ice cubes
rotated the ice bridge adjustment screw clockwise about a 1/8 turn in between freeze cycles. thich direction makes the ice thicker.
Mar 27, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
MY SCOTSMAN ICE MACHINE CO33O FREEZING CYCLE IS TOO SHORT AND IS MAKING THIN ICE
There is usually a sensor that the cubes will touch after the cubes thickness builds to a certain point. This sensor should be adjustible.
Dec 04, 2012 | Scotsman C0330SA 1B 300 lb Cube Ice...
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
English instructions for saivod fhs186 ice maker
DO THE BASICS:
Change the water filter
Add ice machine cleaner and go by the directions.
What should be kept clean?
There are 5 things to keep clean:
1. The outside cabinet & door.
2. The ice storage bin.
3. The condenser.
4. The ice making system.
5. The ice scoop.
The ice storage bin should be sanitized
occasionally. It is usually convenient to sanitize the
bin after the ice making system has been cleaned,
and the storage bin is empty.
A sanitizing solution can be made of 1 ounce of
household bleach and two gallons of hot (950F. -
1150F.) water. Use a clean cloth and wipe the
interior of the ice storage bin with the sanitizing
solution, pour some of the solution down the drain.
Allow to air dry.
How to clean the condenser.
The condenser is like the radiator on a car, it has
fins and tubes that can become clogged. To clean:
1. Remove the kickplate.
2. Locate the condenser surface.
3. Vacuum the surface, removing all dust and lint.
Caution: Do not dent the fins.
4. Replace the kickplate.
Winterizing
1. Clean the machine as explained on the next
page.
2. Turn off the water supply.
3. Drain the water reservoir. See page 24, Spray
Pump Repair and follow the instructions to remove
the pump hose (step 2, bottom hose only).
4. Disconnect the incoming water line at the inlet
water valve.
5Remove control box cover and turn the timer
into the harvest cycle.
6. With the machine operating, blow air through
the inlet water valve; a tire pump could do the job.
7. Drain pump models should have about 1¤2 gallon
of RV antifreeze (propylene glycol) poured into the
ice storage bin drain.
Note: Automotive antifreeze must NOT be used.
8. Replace control box cover. Switch off and
unplug the machine.
CUBE ADJUSTMENTS
There are three items that may be adjusted: Cube
Size, Harvest Time, and Bin Level. Note: Cube
Size and Harvest Time adjustments should only be
done by a qualified service person.
Cube size control.
The cube size control should only be adjusted to
bring the cubes to the correct shape, the overall
size cannot be adjusted. Try to adjust the cube
size control when the ice machine is in the harvest
cycle, or in the first 10 minutes of the freeze cycle.
1. Open the door and remove the control box
cover.
2. Locate the cube size adjustment screw, and to
make fuller cubes, turn the screw clockwise about
1/4 turn. This will make the freezing cycle longer.
3. To shorten the freezing cycle and make cubes
that are not as full, turn the adjustment screw 1/4
turn counterclockwise.
4. After the next freezing cycle, the cubes should
have responded to the adjustment, if another
adjustment is required, do it early in the freeze
cycle.
Diagnostic Codes
Code Description
F - - - - - - - Freeze Cycle
F flashes- - - - Freeze Cycle is Pending
H - - - - - - - Harvest Cycle
H flashes- - - - Manual Harvest
b - - - - - - - Bin is Full
C - - - - - - - Clean Cycle
L - - - - - - - Board Locked
d - - - - - - - Test Mode
O - - - - - - - Off
E - - - - - - - Self Test Failed
1 flashes- - - - Max Freeze - Retrying
1 - - - - - - - Max Freeze Time Shut Down
2 flashes- - - - Max Harvest - Retrying
2 - - - - - - - Max Harvest Time Shut Down
3 - - - - - - - Slow Water Fill
4 - - - - - - - High Discharge Temp
5 - - - - - - - Sump Temp Sensor Failure
7 - - - - - - - Discharge Temp Sensor Failure
8 flashes - - - Short Freeze - Retrying
8 - - - - - - - Short Freeze - Thin ice
All 4 Upper Lights Flashing - Unit Remotely Locked Out
Jul 14, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My ice maker is letting too much water go into the ice tray so it freezes in a solid piece. Cubes do fall down but there is so much water it freezes into a solid block
The icemaker produces small cubes if the water fed into it is not enough and lumped together if too much water is supplied. In order to obtain the desired size of ice cubes, the amount of water supplied to the ice maker needs to be adjusted. Adjust the valve supplying water to the icemaker or the unit in general in such a way that right amount of water fills the ice tray.
Oct 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Samsung model RF265ABPN waxy looking piece fell into ice tray
The waxy piece has a clear plastic bracket, if its not connected, look around your freezer. The waxy piece fits inside the bracket, and attaches to the ice maker, just in front of the ice tray.
The white wire fits inside the waxy piece. It is the thermostat that tells the ice tray when to dump the ice.
This is impossible to feel around for, so you will need to remove at least the bottom freezer compartment as well as the ledge piece from just inside the freezer door. If you are a relatively thin/small person, you can extend the top tray fully outward, and slide underneath. Looking up at the ice maker, the plastic bracket should have a little prong. This prong will attach just behind the ice maker, with the thermostat facing the ice tray.
Jul 05, 2009 | Samsung RF265AA Bottom Freezer French Door...
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Crushed ice only
pull out your ice bin.  in the back of the bin you will see a rod protruding from one side.  That rod goes into an opening in the rear of the freezer. the plastic piece in that opening raises and lowers the arm on the ice bin giving you crushed or cubed ice.  check to see if that plastic piece is froze up or if your rod got stuck on top of it.
Oct 29, 2007 | Frigidaire FRS26H5AS Side by Side...
Kitchen Appliances - Others Logo
46 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
