Question about Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition
Heater not working
My old pool guy bypassed the switch to indicate if the pool temp was getting too high. For the 2nd year in a row my manifolds burnt. My new pool guy replaced them but when he went to undo the bypass and hook it up the right way he said it isnt working anymore. Any ideas?
  • 139 Answers
Yor heater has 3 high limits and a flame rollout switch(aka thermal fuse). be advised that bypassing safetys is not recommended and is dangerous.these component failures are symptoms. we need to find causes.if limits are failing look at sooted or possibly a nest on your heat exchanger. if its a flame rollout problem look at obstructed burner or oriface.
Posted on Jul 01, 2009
I have a Starite heater, natural gas. I replaced the thermistor for the second time in two years. The problem again has returned with the R6 code. The heater just doesn't seem to get hot enough. Shoul
you might want to add a bypass to the heater and not let the full return water through it this is called temp rise to slow the water down so it gets hotter
Apr 30, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater fires up just fine runs for about 20 seconds then shakes and rattles then shuts off and continues same process
this is a water flow problem check bypass valves clogged filter , then thermal regulator and manifold bypass, many time I see when guys blow out line at the end of season the manifold bypass gets blown apart
Apr 09, 2014 | Pentair Mastertemp Heater
Ready to Burst?
sunlight does weaken fiberglass you might be able to just buy the tank or shell a pool retailer should have a parts breakdown and availbility
Mar 19, 2014 | Pentair Fns Plus 48 sqft De Pool Filter...
My pool heater temp control will go off if i raise temp and seems to be not working properley
If its old just order a new one, they wear out with time. Waiting on one to arrive for a hot tub at work. This will be it's 2nd in 3 years (heaters are undersized).
Apr 14, 2013 | Pool & Spa
Hello - I have a Pentair MiniMax NT that is aprox. 5 years old. We have never had any problems with it till this past week. We went to turn on the heat for the jacuzzi, and nothing. The unit shows the...
HI is a code for Water temp over 114. If this is what you have the temp sensor has gone bad. Or thermister. It will be a small tube that slides into the water manifold with two wires coming from it. A white nut sets it in place unscrew this pull out follow the wires to unplug then slip the new one in.
It is also possible that you have enough water flow to close the pressure switch circuit, but not enough to keep the water from getting to 114 F by the time it reaches the temp sensor.
Also, the bypass valve might just need an adjustment . If its bypassing too much water, you will get this code as well.
Hope these ideas help
Apr 25, 2011 | Pentair Minimax NT Heater
What is code 23 for pontiac grand am is it vacume leak
Wow these are hard to find!!
Diagnostic codes for 1987 Pontiac
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 Exhaust Gas Recirculation (EGR) Vacuum Control
33 Mass Air Flow Sensor (MAF) (GM/SEC High)
34 Mass Air Flow Sensor (MAF) (GM/SEC Low)
41 Cam Sensor Circuit
42 C3-I EST or Bypass Circuit Failure
43 Electronic Spark Control (ESC) Circuit
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM Error
52 CALPAK Error
55 ECM Error
If you have your owners manual they should be in there. I couldn't find one online but did find this.
Future reference
http://autorepair.about.com/library/ts/obd-i/bl-dtcs-28.htm?once=true&
I hope these helped you
Nov 26, 2010 | 1987 Pontiac Grand Am
My pool heater exchange is leaking. Is it worthwhile replacing this part $ 699.00 plus labor ? The unit is 4 years old. Can the old part be welded or sodered?
Along with the exchanger you will need header gaskets, manifold gaskets, Pressure switch and tube, igniter or pilot and maybe a temp sensor. I count on all of these when I do an exchanger, total cost about $300.00 Now your over a grand. Labor about two to three hundred, if nothing goes wrong, and hopefully it all get's done right. Now your up over half of a new one and 90 days on parts. I know I make money at this but I make money at rebuilding heaters also. I usually try to get people to go towards the new heater.
Then take a course in pool and spa chemistry. 99.9% of the time this is the cause of a bad exchanger and that is what hurts the other components at the same time.
Sep 09, 2010 | Pentair Minimax NT Heater
Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
May 12, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Fixing our hotel's Hayward CSPAXI55 spa heater.
You can probally get a manuel on line if you go through Hayward.
When he took the old one out he probally just wired the circut together where the temp assembly goes into the cabnet in the top right front of cabnet in the upper panel. Then the temp probe runs around the side to the water header or manifold. If this is in the orignal spot it is on the right of the heater and easy to find. I'm not sure but if the exchanger has been turned then it will be around the back side of the header and it will be on the left side of the heater. Geting a manuel for this is a good idea anyway, good luck.
May 08, 2010 | Hayward CSPAXI11 11Killowatts Electric Spa...
Pentair Minimax Ch 400,000 Btu Propane Pool Heater Millivolt Ignition Logo
324 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
