Question about Echo Backpack Blower PB-500T
Air cap on ignition module Echo PB-500T blower
5 Suggested Answers
roadtech7
  • 297 Answers
SOURCE: can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
Posted on Dec 11, 2010
rycgl
  • 1545 Answers
SOURCE: air cap on ignition module Echo PB-413H blower
The air-gap between the ignition coil module and the magnets of the flywheel is a close tolerance. It is adjusted to about .010"-.012". This is approximately the same as the thickness of a standard size business card. I double the cover and let the magnets on the flywheel (lined up with the coil legs) pull it in tight 9compressing the paper card) and then tighten the adjustment screws. The screws have been known to vibrate loose and the gap would be lost. You can use threadlocker on the screws (optional) or just tighten them down well. Too large an air-gap is bad, but the closer the air-gap, the stronger the spark.
Posted on Dec 27, 2010
  • 122 Answers
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
Posted on Feb 26, 2011
SOURCE: I have an Echo PB-500T blower that won't
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Posted on Nov 15, 2011
Echo pb 500t. Starts and idles OK. When I advance throttle, why does it die?
Hi Alex:
Odds are pretty good that the screen in the muffler is plugged with carbon. The back pressure will stop it from running.
My suggestion?
Remove the muffler. Clean all the bits in solvent and air blow dry.
Re-assemble and
Ta Da!
Cheers
Feb 01, 2016 | Echo Garden
Purge bulb not working on echo pb-500t,gas leaf blower
get a new primer bulb and diaghram and rebuild your carb or buy a new carb,same price,gas and ethanol and oil kill carbs, echo A021000781
Echo PB 230LN 05001001 05020818 Handheld Parts
May 26, 2015 | Echo Garden
Why does my blower floor out to kiwk
adjust need and seat or make sure needld a seat or seated right soundes like not should be no need to adjust needel sounds like put in wrong flip it over metal side go on needle
Aug 06, 2014 | Echo Power Blower PB-500T
Throttle handle trigger is stuck
see if the linkage on the carburetor is stuck
Nov 18, 2013 | Echo Backpack Blower PB-500T
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
Air cap on ignition module Echo PB-413H blower
Dec 26, 2010 | Echo Garden
Can't find serial # on Echo PB-500T Blower
Dec 10, 2010 | Echo Garden
Echo Backpack Blower PB-500T Logo
106 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
