Question about Dell PowerEdge 1800 Server
How do you replace the perc battery? - Dell PowerEdge 1800 Server
    Sergeant:
  • Dell Expert
  • 464 Answers
Should be connected to the RAID Card
Posted on Oct 14, 2014
Why the hard drives are not detected, and when accessing controller from the BIOS no hard drive found only DVD drive ?
You need to access the PERC system at bootup.. Much easier to use a SATA HD and not use the PERC controller.
Aug 04, 2014 | Dell PowerEdge T420 Server
I have Dell PowerEdge 2550 Server. I want to configure RAID, but I can't reach RAID MENU! I have DELL 2550 Server BOOT CD and Dell OpenMenage Server Assistant V7.2. All of them are running, but I...
RAID menu will either be CTRL-A (if you are using the onboard PERC 3/Di) or CTRL-M (if you are using an addin PERC 3/4). If you are not seeing either of these options, then you may not have it enabled in the BIOS. In the BIOS (F2), go to Integrated Devices and make sure that RAID is Enabled. In order to enable RAID, your server MUST have a RAID key, RAID memory DIMM (different from system memory), and a RAID battery.
Aug 12, 2010 | Dell PowerEdge 2550 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
Server making continual beeping noise......
Sounds like one of two errors - either one of the power supplies has died (not sure if the 1800 has redundant power supplies or not) or a drive in the RAID array has failed. Most likely it's the drive. Run the Dell Server Administrator tool to check the health status of the array, sounds like you need to replace a drive. Most RAID systems fail if you lose more than one drive, so I'd replace that drive ASAP.
Nov 09, 2009 | Dell PowerEdge 1800 Server
BCM-95 Icemaker Was working fine until we moved Water does not go in..we have changed the water value and it still does not work.
fi you are using a percing valve you need to change it to a regular 1/2 by 1/4 compression vlve,, go to a half inch cold water line cut a tee in the line install a 1/2 out let pipe fot the ice maker, then install your valve run a 1/4in line to the ice maker, you shoud have no rblems,, it has to have volume with water supply in order to work, a percing valve is just that, it has a needle on the end you clamp it to the pi[e scre in the "t" handle till it perces the pipe, then back it off to open the water suply alot of times this is not enough to supply the water for the ice maker,,
Jun 30, 2009 | U-Line Icemaker
Replacing bad hard drive
Can you explain more about what you are trying to do?
Is this a RAID configuration?
Is it SCSI or SAS or something else?
Thanks!
-Chip
Nov 04, 2008 | Dell PowerEdge 2600 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Thanks and some questions need you
Clear the hardware ESM logs from the open manage or DSET
Check where voltage error comes from ?
If from perc battery - replace the perc battery
if it is Motherboard related - MB replacement needed.
Jul 29, 2008 | Dell PowerEdge 2450 Server
Constant beep on poweredge 840 appears to work alright
Hi
Besides standard beeps codes indicating Processor, CPU, Memory or Systemboard failures,
Dell PERC (PowerEdge Expandable Raid Controller) or SAS Controllers (Serial Attached SCSI) generate beeps to alert failures on the RAID sub-system.
From your description of the issues (when the beeps start), i suggest you check PERC or SAS setup. If you have Dell OpenManage Server Administrator installed, you can log-in and check for more information. Additionally, on the next reboot check the PERC/SAS/CERC boot up for any messages. You may also access the PERC (Ctrl+M), SAS (Ctrl+R) CERC (Ctrl+A) Management Menu for specific failures and attempt a rebuild (assuming you have a redundant RAID Volume).
You can also speak with Dell Support and raise a warranty call if the system has warranty.
Note: PowerEdge 840 would ship with PERC or SAS Controller. PowerEdge 700 will ship with PERC or CERC.
Mike
Apr 02, 2008 | Dell PowerEdge 700 Server
Dell PowerEdge 1800 Server Logo
82 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
