Question about Frigidaire FRS26R4A Side by Side Refrigerator
Refridgerator is not cooling and freezer is not freezing
6 year old side by side.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
6reuud
Posted on Sep 29, 2010
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Sub-Zero 642
Subzero refrigerator freezes
Apr 30, 2012 | Refrigerators
Frost developing inside the refrigerator on the bottom two shelves
Apr 29, 2012 | Sub-Zero Refrigerators
We have a refridgerator, about 2-3 years old, Model #ED5JHEXTB00. Side by side freezer, refridgerator that is not cooling as much as it should in the refer part. I'm not sure of the temp, but milk goes...
if your noticing frost on the back wall you have a defrost problem and need to address it immediatley before u get warm in freezer and refrigerator sides remeber that a refrigerator is just a cold air duct from the freezer.... defrost heater bimetal defrost thermostat ot timer defrost control is bad ...
Feb 01, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Our Kenmore is a side by side with ice maker. It's about 6 years old. The ice maker quit making ice about a year ago. We didn't get it fixed. Now our refridgerator section won't cool. The freezer works...
Find the vent in the refrig that gets the air blown in from the freezer. When the unit is running you should feel air coming out of it. If not then you have a problem with the damper door. you can manually open the damper door but you might have to adjust it so it does'nt send in too much freezer air and freeze stuff.
Sep 08, 2009 | Refrigerators
Not cooling/freezing THERMADOR SIDE BY SIDE REFRIDGERATOR BUILT IN
Sounds like thatyou refrigerator has leaked out the refrigerant. If you have a condenser i.e. cage on the back , place your hand over it and see if it is warm if it is not then if deffinaltey the gas.
this is not a diy job and you will need an engineer with relevant qualifications..
hope this helps
cheers wash doctor
Aug 25, 2008 | Refrigerators
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
151 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
