Question about Uniweld UNF3 Nitrogen Flow Indicator 50 PSI
Where can I get repair kits for the UNF3? - Uniweld UNF3 Nitrogen Flow Indicator 50 PSI
What is the difference between the Simmons Yard Hydrant 850 repair kit and the 850SB repair Kit? The pictures of the parts look the the same. The price is a few dollars different. My hydrant was new...
The 850SB is a lead-free hydrant and the 850SB repair kit maintains that lead-free build.
The two repair kits are identical beyond that lead-free status. If you have the 850 hydrant, the 850 repair kit will be fine. Since the rest of the hydrant may contain lead, there is no advantage to using the lead-free parts. (If you live in California, you may need to get the 850SB kit. The rules for products with lead in California are a bit different than those in other places. So the company only sells the lead-free model there.)
I hope this helps.
Sep 16, 2011 | Sport & Outdoor - Others
The green indicator light wont stop flashing
That can usually be repaired by installing the repair kit called the V26 Chassis DM / Power repair kit. The kit contains the parts and the CD with detailed instructions. Its at www.tvrepairworld.com under the Mitsubishi repair kits.
Jul 10, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The timer lights keeps blinking and it wont turn on
The V23 DM repair kit at the following link should repair that issue. The kit contains the parts and CD with instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Nov 07, 2009 | Mitsubishi WS-55413 55" Rear Projection...
T.v suddenly looks like 3d
Heres a repair kit that will usually repair that issue with the RCA rear projection TVs. The kit has the parts and instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-itc222-convergence-option-missing-repair-kit/cName/repair-kits
Jul 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color
you need to install a convergence repair kit which should take care of that issue. Heres a link to the repair kit for your model. The kit contains the parts and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/av48wp30-convergence-repair-kit/cName/convergence-repair-kits
Jul 05, 2009 | JVC AV-56WP30 56" Rear Projection...
Colors are off
Thats a convergence Issue, Heres a link to a repair kit which contains instructions on how to install the repair kit
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Jun 22, 2009 | Philips 46PP9302 46" Rear Projection...
My Panasonic CinemaVision 47" won't turn on.
Thats the error for the convergence. The following repair kit will usually repair that. The kit contains the parts and instructions with pictures on how to do the repair. Heres a link to the kit for your model. http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
May 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Doubling
you can get the convergence repair kit to repair that problem at this link. The kit contains both ICs and the feed resistors, and also has instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/zenith-r50w46-r57w46-convergence-repair-kit/cName/convergence-repair-kits
Feb 02, 2009 | Zenith R57W46 57" Rear Projection...
I have the Zenith R56W36 56 in. Rear Projection Television, and im getting a 3d affect is there a way to solve this problem?
yes the convergence needs to be repaired. You can get a kit for your model which includes both convergence ICs and all the feed resistors . the kit also includes free instructions so you can do the repair yourself. Heres the link to the proper repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/r49w36-r56w36-convergence-repair-kit/cName/convergence-repair-kits
Jan 24, 2009 | Zenith R56W36 56" Rear Projection...
Uniweld UNF3 Nitrogen Flow Indicator 50 PSI Logo
230 people viewed this question
Top Uniweld Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Uniweld Measuring Tool and Sensor Expert? Answer questions, earn points and help others
