Xrocker speakers issue - Audio Players & Recorders
Intermittent speaker performance - receiver issue - not a speaker issue
Matt,
Have you checked/cleaned the leads on each speaker as one bad lead or speaker can pull/push extra power from/to other speakers causing shorts, this is likely not the case but could be the easy fix. Try cutting one speaker out at a time rotating which one is disconnected to see if this fixes the issue and possibly points out either a bad speaker or connection.
Dec 04, 2013 | RCA Onkyo Ht-r510 Receiver 6.1 Channel...
I need to know where to purchase a replacement x rocker a3 cable
You can basically find that kind of cable anywhere...radioshack, bestbuy, amazon...etc
Here's the amazon link: http://www.amazon.com/RiteAV-3-5mm-Stereo-Female-Cable/dp/B0018MI5F6/ref=sr_1_3?ie=UTF8&qid=1298935185&sr=8-3
If you want to go shopping around at stores for it, all you have to ask for is for a Male 3.5mm to Female RCA audio cable
Hope This Helps!
Feb 28, 2011 | Pyramat Sound Rocker Gaming Chair
How to hock up the Xrocker chair to your ps3 system?
I believe there is a cable that comes with the chair that goes into the USB port or something, my brother had one of their older PC chairs and there were audio plugins on the side of the chair which ran into the computer.
Rylan
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Monitor speakers do not work
Issue: Computer speakers do not work.
Cause: This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
Refer the below link for the solution
http://www.computerhope.com/issues/ch000034.htm
Nov 26, 2010 | HP Vs17 17" LCD Flat Panel Monitor
MY ACER COMPUTER DO NOT HAVE SPEAKERS HELP
The question here is confusing as you have mentioned both Monitor issue and the speaker issue.
If its a speaker related issue, well you can get an amp Speaker set from any electronic shop. If you want resolution for a monitor related issue please write back. Good Luck
Feb 14, 2010 | Acer AC711B 17" CRT Monitor
How do we connect xrocker chair to xbox360
There should be an adapter that came with your xrocker chair. Plug in the standard sound outputs into the adapter and plug the other end into the chord that connects to the chair.
Feb 14, 2010 | Pyramat Sound Rocker Gaming Chair
Only my right speaker works and the sub
I worked it out. I was having the same problem. you probably have the GREEN EARPHONE JACK plugged into the GREEN INPUT PORT on the side of the xrocker? simply move the GREEN EARPHONE JACK to the BLUE OUTPUT JACK on the xrocker and your sorted :) it was really bugging me so i messed about until i sorted it :)
Sep 20, 2009 | Pyramat Sound Rocker Gaming Chair
Install cd for monsoon
What makes you think you need special drivers for your Monsoon speakers? Do other speakers work properly when hooked up to your PC? Borrow a pair from somebody else if you don't have any other speakers you can try, and check. If they don't work either, Monsoon drivers are not your problem. I'm not saying nobody ever needs drivers for speakers to work with a computer, but normally, drivers for the speakers are not the issue if you're not getting sound through them.
The sound card driver and sound settings in BIOS, sound settings in Windows and for the sound card, and physical issues about the way the speakers are hooked up or whether the speakers themselves are functional are much more common sources of trouble than drivers for the speakers.
Start your troubleshooting process with this webpage:
If that one doesn't seem to address your issue, try websearching for other options with a phrase such as: troubleshoot no sound PC speakers.
May 31, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
