Question about Nabi 2
Nabi 2 got wet won't turn on - Nabi 2
Can't find manager in settings
[NABI 2] Free up Internal Storage - Basic Ti... ' Fuhu Nabi 2 - XDA ...
forum.xda-developers.com > Fuhu Nabi 2 > Nabi 2 General
Jan 7, 2013 - 9 posts - ‎5 authors
Fuhu's Nabi 2 comes with 8 GB of internal storage, but the actual space available for app install evaporates quickly. Here are ... 2 (quote) Well you can't over root. .... I dont understand how the nabi2 settings sees huge space under ... I was never able to getExt2Int working properly so I abandoned that route. [TOOL][NABI2] NabiLab - Root, Play, Recovery
Jan 17, 2013
Fuhu Nabi2 Backup - Recovery - Root - Gapps ...
Nov 27, 2012
More results from forum.xda-developers.com
[PDF]nabi 2 User Manual - Abt
Dec 28, 2015 | Nabi 2
How long do the screen turn on after I reset it
Cannot get Wopad to turn on sometimes ' Android Tablet Forum
www.androidtablets.net > ... > Rockchip RK2818 Tablets
Dec 28, 2010 - 11 posts - ‎9 authors
It would do this in seconds. the screen would just turn black, like it does when you tap the .... Hi do you know hw to reset the wopad and how to eliminate this *process ...Now I can always turn it on, even after a long standby.
reset nabi 2 tablet if pattern lock forgotten? - Android Forums at ...
forums.androidcentral.com/...tablets/248800-reset-nabi-2-tablet-if-patter...
Jan 31, 2013 - 9 posts - ‎8 authors
How do you factory reset the nabi tablet 2? My child put ... Turn off your Nabi (To turnoff Press and hold the Power button for 3 seconds) then tap OK 2. Press the ... From your screen press the Volume ? (Low/Down) then the Volume + (Up) button. 5. Press the .... These Before & After Couple Photos Just M..
Dec 25, 2015 | Easy Wopad 7 inch Google Android 2.1...
We lost the charger to the nabi were can we get a replaement
Hi Negretta.
Lots of choices out there on Amazon
Amazon com nabi charger 2 , Nabi
nabi 2 Android Tablets for Children Power Adapter Replacement , or eBay
Nabi 2 Charger
You should be back up and running in no time!
D
Dec 09, 2015 | Nabi 2
My nabi wont turn on
Here are trouble shooting tips from the Nabi site:
https://www.nabitablet.com/support2/fb/top-10-faqs/nabi2/2
Also, there appears to be a problem with the wall charger so it's better to charge it via USB to computer instead of from the wall outlet. That might be the reason why your Nabi won't turn on.
Here's more information regarding the charging problem:
https://www.facebook.com/nabitablet/posts/301200709922574
Oct 06, 2015 | Nabi 2
Why would the green power button stay on on my nabi 2 and not turn on
It is possible that either the operating system has gotten corrupted or that the backlight and/or the screen has malfunctioned. Has the unit been dropped or gotten wet? If so the screen may have become damaged.
If there was no physical damage then you can try performing a factory reset (or "hard" reset) of the device. This will likely result in losing anything you've saved to the device but you should still have access to redownload apps or purchased software.
Factory Reset:
  1. To perform a factory reset, first make sure that nabi is powered off. Then, hold down the Volume - Button and the Power Button simultaneously until the Factory Reset screen appears.
Feb 28, 2015 | Tablets & eReaders
Nabi tablet problems
Try to reset it by holding down the power button for 7 seconds or so, then release and start as normal.
Aug 31, 2014 | Nabi 2
My nabi tablet is charged but wont turn on
Try a different charger first, as it maybe faulty. If not the battery maybe faulty and I would purchase a new one.
Mar 16, 2014 | Nabi 2
Wet tablet
Put it in a large bowl. Then add rice. Rice has a habit of soaking up water. After a few days try your luck and turn it on.
Nov 14, 2013 | FUHU Nabi 2 Android 4.0 Tablet for...
Nabi will not charge .have new charger
Whenever you plug in your Nabi 2 tablet to charge, The tablet will boot up. Whenever tablet boots up, turn it off and leave it charging for a good 4 to 6 hours. That should charge it.
Aug 12, 2013 | Nabi 2
Nabi 2 Logo
22 people viewed this question
Top Nabi Tablets & eReaders Experts
Steve
David Payne
David Payne
jeff5may32
Are you a Nabi Tablet and eReader Expert? Answer questions, earn points and help others
