Savin envelopes won't print
Using Word 2010. Job sent to printer, envelope feeds through, no print on envelope. Savin 9025b
checkitright
  • 1362 Answers
SOURCE: envelope printing
did you go to the menu in the printer and set it in yhe paper options to envelope? You MUST also set it in the PC.
Go to
1- file
2-Print
3-right click on your printer
4-Properties
5-Device settings
6- set tray 1  to envelope
Posted on Oct 15, 2007
SOURCE: Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Posted on Jan 29, 2008
  • 39 Answers
SOURCE: CANNOT PRINT ENVELOPES
you can only print paper not envelope
Posted on Feb 09, 2008
SOURCE: no longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Posted on Apr 18, 2008
i just wont be using the printer for printing envelopes. I have a problem with having to pay for support on any product.
Posted on Oct 06, 2008
I have a savin 9060 and it is telling me I have an error 92 can u help me??
What do error codes 91 and 92 in the error log mean?
91: The job was reset by the device.
92: The job was manually reset by a user.
Dec 18, 2014 | Savin 9060 Copier With Feed, Finisher,...
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Trying to print on a #10 envelope from iMac 27 with Os 10.5.1 using iWork. Printer will not load paper
I am on an iMac using OSX 10.5.8 and printing on an Epson R1800. With iWork, word processing module I set up the envelope to print and under the File menu, select page setup and choose #10 Envelope with Portrait orientation. I feed the envelope into the printer in the normal horizontal, top first, print surface up. In the File menu I select Print and hit Return. Most of the time this works. Sometimes the envelope feeds through without printing, and occasionally the envelope won't feed but the printer goes through the printing cycle. The R1800 is not the ideal envelope printer. It is made to print photos on photographic paper. I use an old fashioned typewriter to address envelopes.
Jul 11, 2010 | Epson Stylus Photo R1800 InkJet Printer
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
don.farr@verizon.net
Oct 19, 2009 | Savin 9935DP Laser Printer
Oct 03, 2008 | HP LaserJet 1220 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
jasbo
jasbo
