Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
Sound Blaster Live 24 Bit, no sound
I replace the mother board on my dell dimensions 8400 computer and I now have no sound. I have unistalled and reintalled sound blaster 24 and still have no sound.
  • 255 Answers
. Right click on Mycomputer, select properties
2. Select hardware
3. Select Device manager
4. double click on the sound,volume and controller
5. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
6. then select Action from the menu bar on the top and select scan for hardware changes
**** after doing this.. you can check the follwoing steps for trouble free ******
7. double click system device
8. if any yellow color pointed is displayed on any option then right click on the option and uninstall it
9. then select Action from the menu bar on the top and select scan for hardware changes
10. then it will start scanning your new hardware and ask for the installation drivers.
Posted on Jun 30, 2009
Reinstalled Windows XP on a Dell Dimension 8400 and The local area connection is not detected. Cannot seem to find drivers through Dell support
Dell Dimension 8400 PC"s use either Broadcom Extreme Ethernet controllers OR, on SOME models of the 8400 that do NOT have ON-board Ethernet connections, SMC Networks Ethernet Drivers. I've seen MANY a Dell Dimension.
Sep 11, 2013 | Dell Dimension 8400 PC Desktop
Can not get computer to power back up no lights on front o rear just little light on mother board have dell 8400
Bad Power Supply, sscorbett.
Usually you have enough power to light LED lights, (Like the harddrive activity LED light for add-in cards, that you see on the motherboard), and spin fans, but Not enough power to turn the Processor on.
Dell Support >Dimension 8400 > Service Manual
http://support.dell.com/support/edocs/systems/dim8400/SM/index.htm
Technical Overview > System Board Components
http://support.dell.com/support/edocs/systems/dim8400/SM/techov.htm#wp1052739
harddrive activity light for add-in cards (SCSI LED)
The Dimension 8400 comes with an ATX style of Power Supply, that has a maximum rated Wattage of 250 Watts.
1) ALL of the LED lights combined use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts
3) A typical Processor can use 51 to 125 Watts.
Your Power Supply just has enough power to light that LED light.
Weak voltage power rail.
Replace the Power Supply.
[ There are three power rails inside that SMPS.
Switched-Mode Power Supply.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail ]
The ATX form factor for a Power Supply refers to the size, and shape of the case, for one.
Approximately 6 inches Wide, 5.5 inches Long, and 3-1/2 inches Tall.
The ATX power supply case in the Dimension 8400 however, is shorter in length.
It is 4 inches Long. (Depth)
Not an advertisement for the website, nor manufacturer.
Reference for the case size, and power cables needed,
http://www.cputopia.com/hp-400w-dell-dimension-8400.html
Scroll down to see the connectors of the various power cables needed.
You may have a Power Supply with these dimensions, and needed power cables, in an unused computer.
Perhaps someone has upgraded to a better computer, and has an unused computer that you can temporarily borrow the Power Supply for a test unit.
Make sure it has at least 250 Watts (Maximum rated wattage), plus,
1) 20-pin ATX main power cable. (Or a 20 + 4-pin ATX main power cable)
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[ 20 + 4-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4 ]
2) 4-pin ATX +12 Volt power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Plus the various power cables needed for the Harddrive, optical drive/s, and computer case fan/s, if it/they do not connect to the motherboard.
Oct 21, 2010 | Dell Dimension 8400 power supply ** FREE...
How do i replsce the sound card on dell dimension
The sound card is on the mother board, but you can buy a PCI sound card and install it in one of the empty whit slots on the mother board.
I am not sure but you may need to dissable the onboard sound before you install the add in replacement sound card.
You can ask dell support if you need to do this, www.support.dell@dell.com
Good luck. I hope this helps. Have a good day.
Jun 01, 2010 | Dell Dimension 3000 PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Audio card not recognized
Try downloading cmedia,this should solve your problem
Feb 14, 2010 | Dell Dimension 8400 PC Desktop
No sound from speakers using sound blaster live 24-bit
go to dellsupport.com and redownload the audio drivers for your system. Hope that helps.
May 25, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
PSU and Mother board Damaged
You should be able to find stuff for that dell on ebay good luck Jonny
Mar 13, 2009 | Dell Dimension 8400 PC Desktop
Dell Dimension power problem
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
My computer have no sound
look in your sounds options and see if it is checked digetal only.If it is then uncheck that box and try again.
Sep 21, 2008 | Computers & Internet
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
313 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
