Question about Crafts & Hobbies
Reset code for TMCC SD80? - Crafts & Hobbies
Which command base will work with MTH dcs
You will need to add a TMCC Command Base and the required TIU/TMCC serial interface. This will allow you to control Lionel engines with the DCS remote. Please see page 100 of the DCS Operators Manual fifth edition.
Nov 13, 2014 | Crafts & Hobbies
Where can I get a copy of the Trainmaster Command Control operators manual?
See pages 17 - 23 of attached Manual/PDF.
The manual may not be for your unspecified locomotive,
but the TMCC instructions will apply.
Lionel Service Manuals
May 15, 2014 | Crafts & Hobbies
HDC-SD80K camcorder does not turn on when I open the screen
If it is brand-new, or near-new, and it is defective, then exercise the warranty to get it repaired or replaced.
Mar 15, 2014 | Panasonic HDC-SD80 Camcorder
Will a dvr/tivo built for direct tv convercablet to a cable tv service with a cable card from suddenlink its a sd80 tivo dvr mfg 2004
Unfortunately, DIRECTV TiVo DVRs will work ONLY with DIRECTV. They cannot be modified to work with cable.
However, there are many TiVo boxes that do work with cable and they are as low as $99. See, for example:
http://www.weaknees.com/4
http://www.weaknees.com/5
Oct 28, 2013 | Televison & Video
Card unlock SD80
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 12, 2012 | Panasonic HDC-SD80 Camcorder
I just got my Panasonic HDC-SD80 in the post. I am charging it but tried to turn it on just for a quick look. The camera turned on and I could scroll through the menus on the touch screen and stuff but...
sometimes this happens if there is a fault with the memory card. switch the camera off, take the battery and memory card out, leave it for 2 mins, put the battery in (DO NOT PUT THE MEMORY CARD BACK IN) wait for the message on screen saying no memory card detected. switch off camera, put memory card in, switch on the camera, this normally cures the blank lcd screen issue
Aug 22, 2011 | Panasonic HDC-SD80 Camcorder
Is there somewhere i can get a hold on a manual for panasonic hdc-sd80
You can download the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/HDCSD80-MUL.PDF
Jul 15, 2011 | Panasonic Cameras
I have a pinhole leak in my pool filter. It is a SD80 tank. Can it be fixed or do i need a new tank?
If it is only a pinhole it should be an easy fix. First dry the unit thoroughly, the drier the better. Then use superglue gel to patch the hole from both sides.You may wish to smooth the glue for aesthetics just make sure you leave enough so the glue can hold to the interior under pressure. The gel will dry overnight and is non-toxic. Larger holes or cracks would require a plastic welder or applying fiber glass.
Apr 17, 2011 | Pentair Garden
Crafts & Hobbies Logo
29 people viewed this question
Top Crafts & Hobbies Experts
Debbie
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
