Question about Mitsubishi Office Equipment & Supplies
NSH200MDA STATUS LIGHT
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
What does the status light mean,it's green
When it's green that just means that you're phone has service. When it blinks red that means you have a text message, virgin alert, missed call, or sometimes a voicemail message. You can turn of the status indicator light by going to Menu > Settings > Display > Status Light and select "Off".
May 10, 2010 | LG Flare Cellular Phone
Status light isn't lit
If status light won't lit, there might be inside hardware problem in the router or maybe just the led is broken. Does your router still works just the status light wont lit or status light won't work plus the router? If the 2nd case is true then the router may be broken.
Jan 03, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
No picture, no status light
This isn't a permanent solution, but it has worked for me. The first time I found out about this solution was when the status light went out on my Tatung. I just left it unplugged and didn't plugged it back in for about a month and a half just to see what it would do. When the status light came back on, I knew if it ever did it again, I could try the same thing. Well, a week ago last Sunday, the status light went out again, so I just kept track of when it went out and when I plugged the power cord back in to see if the status light would come back on. Today when I plugged the power cord in, the status light came back on. That was 9 days. I don't know if it could be less than that because the last time I plugged it back in to see if the status light would come on was around last Friday. So it might have worked sooner. Anyway, this seems to work for me. I don't know what is causing it to lose power in the first place, but at least I know what to do.
Dec 23, 2006 | Tatung V30DMTT 29.6 in. LCD Television
42 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
