Question about Samsung Healthy Living Bsd 3007 Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector
Where can i buy an extra large cuff - Samsung Healthy Living Bsd 3007 Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector
I'm looking for an extra large arm cuff for an automatic arm blood pressure monitor model WGN BPA-530. I have been working out and arm is now 15. Thanks for your help Eric in Fresno Ca.
as you will notice that there is now a blood pressure machine that clips around your wrist
try wrapping the cuff around your wrist or lower arm
Nov 12, 2017 | Health & Beauty
Is there a larger size cuff
they do have large size blood pressure cuffs, I would call the company that made yours and ask if that is something they can help with. otherwise ask your pharmacist, they may know where you can buy one. hope this helps.
Nov 10, 2017 | Health & Beauty
Why does my Walgreens digital blood pressure monitor keep giving an ERR4 message?
Here are the top 3 reasons for getting errors: 1. You're using the wrong-sized cuff. If you are extra large, you need a larger cuff. 2. You've incorrectly positioned your body. Ideally, your arm should be at the level of your heart. 3. You've placed the cuff incorrectly. Make sure the cuff is on your upper arm and the stethescope is placed over the place you feel the strongest pulse. I hope that helps!
Mar 30, 2017 | Walgreens Health & Beauty
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Have a CVS blood pressure unit BP3MU1-1E. The cuff is too large for my 95 yr. old mother. How do I get a smaller cuff? The stores have none!!
Switch to the leg. You can take the pressure on the calf or the thigh. The thigh is easier. Place the cuff closer to the knee and if the sensor can be seen on the units cuff put that under the leg close to the knee joint. Inflate as normal. The reading may be higher than you expect by 10% So if it says 140/80 it would be 126/72
Sep 21, 2014 | Health & Beauty
Nned a larger cuff for taking blood pressure.
a standard cuff is at the size of 22 - 32mm, and a large cuff is at the size of 22- 36mm, there is also a extra large cuff size too.
Jan 11, 2011 | Homedics Health & Beauty
We have a large adult cuff. The index is in the "select adult cuff" zone. Is there an adult cuff for this unit that is interchangeable ( so we don't have to purchase a whole new unit...just a...
If your arm circumference suit this "large adult cuff" and the machine give good result, you dont need to change the cuff. Otherwise, you can just ask for replace with just a regular size cuff 22 - 32 or 36mm
Jan 06, 2011 | Mabis Health & Beauty
Where can i find an extra large cuff for my digital homedics blood pressure monitor
just go onto the homemedics site and take a look they probably do an extra large one ok good luck.
Apr 18, 2010 | Homedics Bpa-300 Deluxe Auto Blood...
I have a Marshall BP monitor. My large cuff tore
Replacement cuffs are available on eBay. Here is a link to the page. [http://shop.ebay.com.au/?_from=R40&_trksid=p3907.m38.l1311&_nkw=blood+pressure+cuff&_sacat=See-All-Categories ]
Mar 30, 2010 | Marshall Health & Beauty
I need a smaller pressure foot to finish cuffs on baby clothes. Any suggestions? I have the extra kit with it as well but all the pressure feet seem to large to fit inside the little arm and leg cuffs.
I honestly never heard of anybody having this problem before and never heard of smaller size pressure feet. One way of avoiding the problem altogether may be to finish the cuff before you sew up the arm seam ( you can also finish the side seam of the body and arm seam in one "stretch"). Using this method, you can finish the cuff with the whole arm lying flat. I haven't sewn baby or doll clothes for a long time myself though, can't remember having any problems though. I remember having a challenge finishing sleeves on a toy dog rain suit though (much smaller than a baby sleeve), but that I handled in the way above, I opened the sleeve seams, finished the hem with elastic, then did the arm seam again.
Sep 14, 2009 | Husqvarna Huskylock Computerized 936
Samsung Healthy Living Bsd 3007 Deluxe Thinline See Thru Flat Screen Blood Pressure Monitor With Irregular Heartbeat Detector Logo
Top Samsung Health & Beauty Experts
Md Fazlurrahman
Md Fazlurrahman
Level 1 Expert
Joe Ball
Joe Ball
Are you a Samsung Health and Beauty Expert? Answer questions, earn points and help others
