Question about HP LaserJet 4650 Color Printer
Black vertical lines on laserjet 4650 print out
    Problem Solver:
  • 7 Answers
99% of the time, this is the imaging drum or fuser.
Pull the imaging unit (same as imaging drum - they are interchangable) and examine the greenish glass tube. Does it have black streaks along the same lines that are on the paper? If so, then it needs cleaning / replacing. Don't touch the glass!! Use Q-tips and rubbing alcohol to gently clean the lines off. Air dry and replace into the machine.
If the imaging unit doesn't have lines, then it's the fuser. This can be replaced as part of a maintenance kit. If you've been using the printer regularly for more than 9-12 months, It's probably time for a Maintenance Kit for the machine anyway, which includes a fuser. I recommend Parts Now (http://www.partsnow.com/) for replacement kits, which have instructions on how to install with them.
Posted on Jun 22, 2009
  • 81 Answers
I'd would put this fault down to the ITB ( image transfer Belt ) that sits at the front of the printer in front of the toner cartridges.This will wear with use and start to exhibit lines on the belt which can then transfer toner to the page
Posted on Oct 13, 2009
    Problem Solver:
  • 7 Answers
You have to change photodeveloper.
3 Suggested Answers
SOURCE: HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Posted on Mar 21, 2009
  • 214 Answers
SOURCE: HP Laserjet 4650 color printing problem
More than likely you need new drum.
Posted on May 06, 2009
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
My hp 4650 printer only prints the first line
check the inside of your printer where it moves and check to see if any thing is jammed in it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_a883c83ebf74d9a6
Aug 06, 2012 | HP LaserJet 4650 Color Printer
Hi. I am getting vertical lines on all my colour print outs. I didn't have this issue when I initially purchased the printer. Any help please? Thank you.
Hello ,, Which olour of line in your colour printout ,first findout the colour & replace the concerning tooner your problem will be resolved.
jm
Sep 07, 2011 | HP LaserJet 4650 Color Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Mar 20, 2009 | HP LaserJet IIIp Printer
Pink lines and background on all prints
I have seen this recently on an HP 4250 and the red toner cartridge was at fault. Can you replace it and try to print again?
Jan 14, 2009 | HP LaserJet 4650 Color Printer
HP LaserJet 4650 Color Printer Logo
1,501 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
