Question about Troy-Bilt tb2bp ec backpack gas leaf blower
Is there an air filter than need to be periodically replaced or cleaned? Symptoms are...it starts but give it more gs and it dies...like it becomes over choked As it runs at idle and heats up, I readjust the choke setting, more but never get to the lowest...or highest.
rwvanlue
  • 486 Answers
SOURCE: Will not continue to run after relasing choke, no
you have a fuel starvation (lean condition) issue
fuel system needs cleaning
fuel lines
filter
carburetor cleaning and replace gaskets/diaphragms
Posted on Nov 09, 2009
  • 623 Answers
SOURCE: Engine stalls
I'd say the carb is clogged somewhere, probably the main jet. The gas today is terrible. Removal/replacement may be the (only) way to go.
Posted on May 26, 2010
  • 5 Answers
SOURCE: tb320bv blower, I can set the choke and start it
This would indicate that you need a new diaphram in the carby not very expensive any mower shop will do for about $30
Posted on Jun 25, 2010
rycgl
  • 1545 Answers
SOURCE: My 4 cycle BP blower will run with the choke
The carburetor needs to be cleaned and/or adjusted so if you do that, you may as well install a low price gasket and diaphragm kit in it. This will alleviate all the problems that you mention. I don't know your model number else I could give you the part number for the carb kit to install. This solution works most of the time.
Posted on Sep 06, 2011
  • 4 Answers
SOURCE: My Troy-Bilt TB320BV blower will not run unless fully choked.
Replace intake air filter
Posted on Mar 29, 2013
2002 Cavalier starts then dies. Started about 1 week ago. Let sit overwrite started fine next afternoon. Ran great for several hrs. Started dying again. Replaced fuel filter, Ran great for a day. Now it...
Had a 89 cavalier did that start then die it map sensor. Also check ground wires if the become too corroded they won't start sometimes just run weird
Jan 21, 2015 | 2002 Chevrolet Cavalier
Craftsman chainsaw will not keep running
Most saws will have a high, low and idle screw adjustments.
First make sure we are dealing with a clean air filter, clean with air or tap air filter and brush to remove saw dust. Replace fuel if it is a season old or older. (Fuel filter replacement if it has seen years of use.)
2nd GENTLY turn the high screw clock wise until it bottoms out and then counter clock wise 1 and a quarter turns.
3rd do the same for the low idle.
It should run and idle at this point, let it warm up before making final adjustments. If it dies when giving it gas then more than likely it will need further adjustment on the low idle screw.
If it is really stubborn, often times the the ports are full of sludge from the bad fuel. I prefer to remove the bar and chain especially for the novice. Start the saw, secure with another set of hands if need be, turn the idle screw in to quicken the speed a little. Now you can work the low and high screws back and forth 1/4 turn while the saw is running, periodically giving it full throttle. That should be enough to dislodge buildup replace bar and chain and then your final adjustment.
If not you may have to look else where as in an air leak.
Good luck and be careful!
jeromekj
Dec 29, 2013 | Craftsman Garden
2002 HD 1500 Chevroley 4WD 4 door truck engin lost power and died could start but when acelarated died max rpm 800 pulled filter turned key on pump shot a stream of gas 3 ft and stoped ran only secon
It is normal for the pump to run for two seconds when first switched on to pressurize the fuel system. It will turn on again when cranking and while running. I would still suspect the pump given your symptoms, however other problems could also give you the same symptoms. If it is the original pump from 2002, or more than about 7 or 8 years old, I would definitely replace it, and the fuel filter. Often the pump will go intermittent. I had one that I could restart and get down the road by hitting the bottom of the gas tank a few times!
Oct 18, 2017 | 2002 Chevrolet Silverado 1500HD
My 03 tahoe dies when it comes to a complete stop... I can start it but when I give it gas in the park position and let it come back down to a idle it dies... I have replaced all spark plugs and wires... I...
thats what it sounds like, a bad or clogged up fuel filter. if it bogs down when giving it gas, or going up a hill. its probably the fuel filter not letting enough fuel to engine. that is why it stalls at a stop. if this helps but not fully. check or clean idle air control motor. this is what maintains proper idle of vehicle. have a good day !!
Mar 31, 2011 | 2003 Chevrolet Tahoe
My fazer 600 w plate when i give it a good hand full it burbles and dies and then wont start for a good 3 mins when it restarts it seems to have more power this also has started to happen when riding...
If the carbs were jetted for a different pipe,and you have changed it back to standard that will cause your symptoms,if it was doing the same before you changed the pipe your carbs need cleaning
Mar 17, 2011 | 1999 Yamaha FZS 600 Fazer
My 95 lexus gs 300 wont start
Try to replace the fuel filter and then check the spark plugs. Mke sure to clean the spark plugs and after you clean the spark plugs and still the same it wont start replace the spark plugs and check the distributor as well.
Feb 02, 2010 | 1995 Lexus GS 300
Oil and fuel leaking out air filter housing, won't stay running Starts rough then dies as it warms up (with in 2-3 mins) looks like fuel and maybe some oil leaking out the air filter. a friend said it...
gasket not possible the thing it could be is floats on a carb is too low so it is filling with fuel and leaking out off carb back through the air filter the way to test for this is to clean the airfilter and just leave the bike for a couple day then go see if the air filters is wet again get back to me once done
Oct 04, 2009 | 1981 Suzuki GS 750 L
It dies when you give it gas.but it startes fine
When it starts it is running on the idle jet and when you open the throttle it is being starved of the correct gas/air mixture. Sounds like you have a blocked air filter or fuel restriction. Take off the air filter and try to start it opening the gas slowly. If that doesn't work, clean the fuel tank filter and try again.If that doesn't work, remove the carburettor and clean it with carb cleaner paying attention to any fuel or drilled holes in the body. Blow it off with compressed air and replace it. Ensure fuel tank has clean gas.
Apr 26, 2009 | Garden
1996 chrysler sebring 2.5l v6 dies randomly
it sounds like it the crank pos. sensor
Apr 04, 2009 | 1996 Chrysler Sebring
Troy-Bilt tb2bp ec backpack gas leaf blower Logo
93 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
