Question about Kenwood VR-606 Receiver
What about 6 channels
Whats the best way to hook up myVR-606 to my 52" Mitsubishi TV? And please remember your talking to a audio video ****.
  • 86 Answers
On the tv there should be Audio An video out Yello,Red,white witch would go on to your reciever, either on AUX, Tv Video so hope that helps
Posted on Nov 16, 2008
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Mar 31, 2015 | Yamaha HTR-5930 Receiver
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
How do I plug my cable TV into the receiver and then into the TV? Whats wrong with the following: 1. Plug the cable into the antenna jack on the receiver 2. Plug the red/yellow/white cable into the...
When we talk about cables in an environment that also includes "cable TV", digital and analog audio; and video we need to be VERY specific.
Therefore, I could be misinterpreting what you meant in the following.
I doubt the receiver is designed to BE your cable box so hooking the TV-source cable to the FM antenna jack on the receiver is probably a bad idea.
If you HAVE a cable or satellite box, treat it like any other audio/video source and run its BEST audio digitally to the AVR and its BEST video to the monitor or TV (*) where the BEST most-specialized electronics will have the first shot at each function. You could also run basic composite video from the AVR out to the Monitor for the AVR's internal setup purposes.
* Even if it means bypassing the AVR. HDMI or DVI, component, composite are the various video outputs in descending order of quality. The TV deserves the BEST video.
If you're using the red/white/yellow cables for analog audo and composite video then you are making a major compromise in the quality of both.
Dec 23, 2010 | Harman Kardon AVR 120 Receiver
I have a mitsubishi black dimond vcr id like to tune into a sharp tv how do i do this please
Ok, to hook it up to use as a Receiver, and TV, as a "Monitor". Using the antenna cable, plug this into the antenna IN socket on VCR. Now connect up, AV, using the Yellow, Video, Audio, is Red & White, on BOTH TV & Video. Now select an EXTERNAL INPUT on the TV. Now You Tune, and scan for "Channels" using the VCR. Find each channel, and save, now, you use the VCR remote to change channels, and the TV, is used as a "Display Monitor".
The Other way, is to just use the VCR as a "Recorder only, you plug the antenna, into the TV, now at rear of TV, you have a Video OUT, Yellow, and Stereo, Audio OUT, Red & White. Connect up the VCR to the TV using them. Now anything you View on TV, will be out put to the VCR, when you wish to record, simply press record, on Remote/VCR as desired. and it will record.
Apr 08, 2010 | Televison & Video
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Hooking updta800 converter
Hopefully, your HDTV has a 'Video out' RCA jack on the back-some don't. You could try connecting from these video/audio out jacks to the RCA video/audio in jacks on your VCR. If it works, remember it will be recording EVERYTHING on the tv screen(Time, channel,etc.) that you see while watching. So if you change the channels on the tv-it will be on the tape.
May 25, 2008 | Televison & Video
No sound - no video on TV
if you're hooking your VCR via analog video input of your TV then check that the yellow colored video wire goes to yout TV video input, will also be colored yellow inside the terminal. The white and red color inputs are for audio. Likewise the output of your VCD will have the same colord code Yellow for video, red/white for audio (stereo). After setting this up, select your TV function to video in, be sure to check your video input channel as well if you're having more than one video input. Video 1 or 2 or 3. Make sure your VCR is powered up when you start to setup your TV function select.
if you're hooking your VCR to your TV via RF signal (over your TV tuner) You need to scan the right frequency to get it tuned to your TV channel. Cabling willbe via RF antenna input of your TV and RF antenna out of your VCR.
Mar 17, 2008 | Televison & Video
Picture, NO SOUND! Please Help ASAP!
What is the source and how is that source hooked up?Is it,for instance,a cable box connected to the tuner/coaxial cable input?-AKA the RF input? The DVD & video are most likely hooked up to video inputs,correct? Hmmm,have you talked to the source box customer service rep yet? By the way,what is your Mits DLP system Model number?? With a bit more info,we might be able to help----
Oct 06, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
HOOK UP INFORMATION
The cable should be on the Input to RF connector. Then you should reprogram tv for cable channels. If you have dvd then it should go to the inputs for 1/2/3 A/V inputs yellow for video, red for right audio and white for left audio. Color coded! Hope this helps!
Aug 31, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Kenwood VR-606 Receiver Logo
53 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
