Question about Contax Cameras
Why xenon lamp not flashing on topcon non mydriatic camera
Non mydriatic retinalcamera model TRC-NW5S have trouble with xenon lamp trigger circuit (280 volt power to lamp ok)please send me a schematic diagram of g1 and g2 boards if any or describe me how xenon triggers
SOURCE: SB800 firing but not syncing??
hi, i had this problem also but found a way around it . what is happening, is that the sb800 preflashes when you shoot and triggers any external flash heads a fraction of a second just before the camera takes the picture. you see the lights being trigered but it the light doesn't register on camera. ( preflasing asseses the amount of light needed for the correct exposure and is a feature on newer models of flashes ). what you can do to avoid this problem is to either use a radio trigger and slave, or set your flash to su-4 mode ,which cancels the preflashing. if you press the select button on the flash .you go into the menu \ scroll up and down till you reach the icon of two flash heads . press the select again and change from " off " to su-4 .that will cancel the preflashing and your other lights will be in sync with your camera . if you get confused go to page 76 in the sb800 manual it explains everything there / hope this was helpful. good luck charles yacoub
Posted on Sep 14, 2007
  • 231 Answers
SOURCE: sony tv model klv-32u100m dead standby 5 volts ok
most probably is (a) board ..very common on these models.These boards are made by RoHM.These are similar and used in maganvox,philips and others..Very common breakdown
Posted on Nov 30, 2007
kalaci
  • 30 Answers
SOURCE: Vivitar trigger voltage
Yes, you can. The flash has a low-voltage trigger circuit.
Laszlo
Posted on Nov 14, 2008
kalaci
  • 30 Answers
SOURCE: camera and flash gun trigger voltage
Hi Syd,
Vivitar 2800 and 2800D are two different flashes. The first is an old flash, having high trigger voltage, which, as you will see, still can be used with your Fuji. The second is a member of modern flashes, having a low-voltage release. Manufacturers specify the highest applicable voltage at the trigger (hotshoe or PC) terminal; at most digital cameras it reaches several hundred volts.I believe, this is, what your seller was asking. As far as I know, Fuji doesn't mention this value in the user manual of the Finepix 9500, but I met reports of people, who called Fuji and asked that and the answer was 400 volts!
So the short answer is: buy any wireless trigger if you have the 2800D, and tell the seller the flash has about 200 volts if your flash is an older 2800.
I wonder if you did already use your flash with your Fuji?
Laszlo
Posted on Nov 28, 2008
  • 4 Answers
SOURCE: wireless flash trigger for vivitar 283
I purchased the Wein Slave Foot. The metal foot is designed to repair the plastic foot that, apparently, is prone to breakage. Mine is not broken, but I purchased the Slave Foot because the blurb stated that it would make my unit serve as a remote slave.
The setup works fine with my Sony A700 using either the built-in flash or in combination with my proprietary external Sony flash.
I have just purchased another used 283 and will be ordering the Wein Slave Foot from B&H in the morning.
Caruso
Posted on Jan 03, 2009
Dsc - w120 flash problem
If tthe flash is not working then it is possible that the unit has failed inteh circuit or the lamp has failed. Unless the camera is opened the fault cannot be confirmed as the trigger unit to the flash comes from the processor, even if this is autto detect. Try to focus into a dark area and see if the flash works, also check the flash with a normal setting, manual setting.
if not it is wise to take opinion for estimate or use the camera minus flash
Jun 25, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Nikon Coolpix S220 flash not working
Dear Sir, possible causes for the flash does not work is in the following order: Xenon tube drained, open coil trigger, circuit oscilator wrong.
In all cases you must use a specialized service.
Greetings
Mar 04, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My coolpix 8800 flash has stopped flashing. what could be the prublem?
Hi cm3me, the xenon tube is bad need be replaced or trigger coil defective.
Regards
Mar 01, 2011 | Nikon Coolpix 8800 Digital Camera
Flash not working
Hi if ready flash led light but dont fire, xenon tube bad or trigger coil bad; if led flashing sb oscilator bad.
Greethings.
Feb 19, 2011 | Nikon Coolpix L11 Digital Camera
Charging flash
Please have the question with clarity as we at Fixya can help out.
If youment flash is not charging, then check if the flash is in auto or manual mode. change as required in the menu.
If not flashing then the faultis within the camera and must be looked into, can be flash lamp, the capacitor or the driver./trigger circuit.
Sep 25, 2010 | Canon PowerShot A480 Digital Camera
The built-in flash on my Canon Powershot pro1 is not firing. The settings are correct and I can hear it cycle, it just won't flash. The pin on the hot shoe is functioning properly.
In that case, either the trigger circuit has partially failed or (far more likely) the xenon flash tube has blown.
Either way the camera needs to go to an authorised Canon service outlet for diagnosis and repair. Or you could just put the repair costs towards a far more useful external flash unit.
I hope that this has helped and that you kindly remember to rate my answer.
Feb 19, 2010 | Canon PowerShot G9 Digital Camera
Bulb metz 45cl
How do you know you need a "bulb"? (I suppose you call bulb the xenon tube.) The flash lamp - actually a low pressure xenon-gas filled discharge tube - is a long-lasting device, goes only wrong if cracked. After several thousands of full-power flashes it starts to become foggy a bit, thus somewhat decreasing the light output. If the flash does not fire, this is rarely an indication of a faulty tube. Some other reasons could result
Apr 04, 2009 | Metz 45 CL-1 Flash
F-5 error
Manual says F5 as copy lamp lightning abnormality.
Never had on AR series Sharp machines this trouble,but remember on old Canon NP 6016 when lamp was bad -no dark ends and low intensity of lightning but intensity too high.This machine was equiped with doc feeder and customer performed a lot of copies from glass only and I think he was damaged lamp when close the doc feeder.
the fluorescent type lamp was used on this Canon-Sharp uses Xenon lamp (I think),but they could be very common in construction (tube with electrodes on ends and gass inside)
This fault is very difficult to troubleshoot-try another lamp first,next sensor from good working machine.
Nov 13, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Vivitar 3200 Flashgun and Canon EOS 400D
Using Vivitar 3200A flash gun on a DSLR is risky for the following reason. The trigger voltage of a DSLR at flash hot shoe that takes it to its TTL (through the lens) circuit is less than 10 volts, it is about 6 to 8 volts in the recent DSLRs. The trigger voltage generated by Vivitar 3200A at full charge flashing is around 180 volts (max). That is a fatal dose for a sensitive DSLR TTL circuit. This high voltage flash gun will work endlessly, the only damage is to the TTL flash circuit. When you attach a TTL flash to the DSLR after using Vivitar 3200A for sometime, your TTL flash will not communicate with your camera. It will be just another ordinary flash without any auto functions. There is a Wein adapter that you can fix b/w your cameral hot shoe and the vivitar flash gun that is said to reduce the trigger voltage that passes into the camera. Try it if you get it. Without this gadget it is better not to use non recommended and non TTL flashes on latest DSLRs.
Apr 13, 2008 | Cameras
Cameras Logo
35 people viewed this question
Top Contax Cameras Experts
Are you a Contax Camera Expert? Answer questions, earn points and help others
