Question about Sharp R-7A95 Microwave Oven
I used the sharp to bake potatoes and after two
I used the Sharp R 7A95 to bake potatoes and after two rounds of baking, the oven died. Light panel etc, all dead.
  • 2 more comments
  • traegers Jun 24, 2009
    Thanks for the info. I'll let you know what happens.
  • traegers Jun 27, 2009
    I've taken apart the microwave and believe I've found the problems. There appears to be a double relay switch found immediately behind the wall where the power cord attaches, and the power flows through that switch. The relay switch, when the little plate is pushed, appears to allow power to flow through. The second problem is a 125 V / 20 amp. ceramic fuse located near the transformer. The ceramic fuse does not have continuity.
  • traegers Jun 28, 2009
    I replaced the ceramic fuse and as soon as I tried to set the clock it blew. So I assume there's a short somewhere. Don't know if it will be cheaper to fix it or purchase another one. Thanks for you help.
  • blueextc3221
    blueextc3221 May 11, 2010
    thermal fuse has failed.
  • Sharp Master
  • 9,098 Answers
Assuming that the internal cooling fan was working properly, it may be as simple as a failed magnetron thermal cutout.
I don't have an exploded view on this one, and the supplier's part list is not detailed properly, so you would have to remove the magnetron thermal cutout and look for the numbers on it, either 145 or 150.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Then here would be the part numbers:
RTHM-A080WRE0 Thermal Cut Out 145 Degree c
RTHM-A085WRE0 Thermal Cut-out 150'C
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
You should also check the 20A ceramic fuse. Fuses can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you need more help, please replay back. Otherwise...
Posted on Jun 24, 2009
  • 1 more comment
  • William Miller
    William Miller Jun 28, 2009
    I'd suspect the fuse:
    "You should also check the 20A ceramic fuse. Fuses can be had locally in most
    Not sure what the "double relay switch" might be. One some models they had a switch that kept the oven from being operated with the outer cover off.
    If you still have concerns about that, please reply back with a clear photo.
  • William Miller
    Are you talking about something in the outlet?
    The may be a ground fault interrupter (GFI).
  • William Miller
    Did it blow when you opened or closed the door, or when you pressed keys on the controller?
    If any of those, I would suspect a problem with the door switches or alignment and would suggest you see these files:
    http://www.microwavedisplay.com/doorsw.t...
    Or was it when you hit Start? Or a few seconds after?
The control panel of my sharp grill 2 convection microwave oven is very dim
Dimmed light might be caused by a slight contact between the panel's connector and the mainboard. Or, there is a dimmer option (feature) in the menu. Depends on model. Some of Panasonic microwave ovens are equipped with such a feature.
Regards,
Dan
Oct 12, 2016 | Sharp R-820JS 900 W 0.9 cu ft Countertop...
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Sharp R959SLMA auto cook not working
please make this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Dec 16, 2013 | Sharp Microwave Ovens
Can i bake cookies on my sharp carousel with bake setting. can i use an ordinary micro safe plate or do I need something else?
yes you can bake cookies in the carousel on BAKE I suggest those new rubber looking bake plates help a lot to reduce the moisture that makes them soft.
I think they are silicone rather than rubber, i am sure you know the ones I mean
Thanks for using FIXYA
Oct 11, 2009 | Sharp R-1850A Convection/Microwave Oven
Have an older sharp microwave with 2 grills and convection but don`t know number probably on back but it is built into kitchen and would be a prob to get it out it has an lcd panel at top ndrneath are 3...
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit and your specific symptoms or question.
Oct 08, 2009 | Sharp Microwave Ovens
Sharp microwave losing cooking power
If the supply voltage is low it will take long time to heat foods. The second reason is the Magnetron. Since it is in the warranty period you can call at the sharp authorised service center. They will do it free of coast.
May 04, 2009 | Microwave Ovens
Microwave Ovens Logo
151 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
