Question about Danbury at Things Remembered Home
How would I go about getting this clock fixed?
How do I fix an anniversary clock from 2005 that runs on one AA battery. Recently replaced battery, it'll run for one day and then slow down, and eventually stop. The plastic battery box has the inscription HD-1688 SHENG BANG made in China on it. Any suggestions?
4 Suggested Answers
  • 6 Answers
SOURCE: what battery is used for the Sheng Bang HD-1688
I do have a Clock with a Sheng Bang HD-1688 Clockwork. There is a normal AA 1.5V battery in it.
Kind regards Marcel van ****
Posted on Feb 10, 2010
SOURCE: anniversary train clock; clock does not work
It's not the motor it's the unit in the middel that works the clock it self. I have the same problem. When the clock passes the hour it is supose to send a signal to start the motor. There are two tiny pices metal that are supose to contact each other on the hour and they break off easy.
You have to replace the clock unit and reconect the two black wires.
Try by passing it. The two black wires that come from the clock unit. Cut them and touch them together. Make sure the light sencer on the front is not covered.
Good Luck
Posted on Aug 20, 2010
SOURCE: My Lacrosse radio controlled clock (IECLR6) has
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
Posted on Dec 02, 2010
How to start clock going
Setting up anniversary clock can be a monster, this link should help you out.
How to set up an Anniversary clock
Oct 09, 2016 | Home
Equity model 29002-1
Anon, replace battery with a good strong AA Energizer or Duracell Alkaline not a cheap battery, make sure battery contact point in clock are clean and no corrosion. If this does correct the problem, the clock mechanism is probably just wearing out from age which is normal unless it is digital. Read through the links and learn how some time mechanisms can be made to work properly again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Maintain Battery Powered Quartz Wall Clock
Save Money Quartz Battery Wall Clock Repair Fixing Disney Winnie The Pooh...
Clock repair and troubleshooting
How to identify and replace quartz clock movement
Feb 15, 2014 | Equity By La Crosse Equity 29003 10"...
I have a howard Miller windable mantle clock 60 year anniversary how do I get it to run or who can fix it.
If you've had it for more than 3 or 4 years, and have not had it serviced, then it may be time. The movement, and springs need to be cleaned, and lubricated about every 5 years or so. You can search for Clock Repair in your general area on any search engine.
I happen to know for a fact there's a clock shop in Ashland City, Tn. Called Clockworks that works on just about anything.
Sep 28, 2013 | Home
My battery operated anniversary clock keeps perfect time, but the pendulum has stopped. It is on a different battery, have changed batteries, to no avail. Can u plz help me? My clock is beautiful, with...
There is a very fine spring wire which makes the pendulum go, they often break when people touch or spin them. Replacements are available. Best to get it done professionally, suspension springs shouldn't cost too much
Sep 28, 2013 | Watches
Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Sep 20, 2011 | Watches
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 | Vacuums
The power was out at my house. I am not sure for how long. When I came home, the time was flashing. I can't seem to fix it. How do you adjust the time without using the time zone button? The hour and...
You do not have to set the clock time as a built-in automatic time set system ise quipped in this clock powered by 3V (2X AA batteries). All you have to do is to plug this clock for power and current time will be shown automatically.However, the batteries can also be exhausted and it is recommended that you replace the batteries every 2-3 years. Probably it is time to replace them.
You can set clock time manually also if you want.
Here is the user manual for your help:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
gylacz
Feb 23, 2011 | RCA RP5420 Clock Radio
I have an out-of-commission German-made Anniversary clock. I would like to try to fix it myself. The thin long spring that is responsible for moving the pendulum at the bottom (Pendulum = 4 balls that...
I had the same problem; I inherited a clock by that description with my office. I'm not sure if it would help you, but I was able to at least figure out the mechanics of the clock from this site: http://www.clockworks.com/cintro1.html
They claim that you can order the spring there.
Nov 12, 2009 | Watches
Home Logo
Top Danbury at Things Remembered Home Experts
Donni Steen
Tom Chichester
Are you a Danbury at Things Remembered Home Expert? Answer questions, earn points and help others
