Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Why is mabe washer soak button flashing - Hotpoint Aquarius WD640 Front Load Washer/Dryer
How do i soak in my machine
If the machine has a soak button on the panel, when pushed, it will fill and wash and then it will stop for around 2 hours. Then it will continue the rest of the cycle. If no soak button is on your model then it won't do any of that.
Oct 20, 2014 | Fisher and Paykel Fisher & Paykel Washer
How can I soak clothes overnight?
1. Open the door to force a soak.
2. Unplug the unit if you're able.
3. Shut off the circuit breaker.
Sep 02, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Ge washer tl1103pbwn
The washer uses a green light, which is the "Start" button, to indicate problems, and the flash pattern is a code to the type of problem. Two flashes means the washer's drain pump must be cleaned. Clumpy or poor-quality detergents can clog the drain pump. The user can attempt to fix the pump, but, If the problem continues, he must contact the GE customericon1.png service line for professional service.
Read more: http://www.ehow.com/how_12129638_troubleshoot-ge-washing-machine-green-light-flashing-two-times.html#ixzz2qLdypTQ0
Jan 13, 2014 | Washing Machines
I have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
\\\my washer flashes a F 21 and doesn't open. I washed my son's comforter the other day and the machine stopped and flashed a F 21 and would not open. when I finally kept pushing the unlock button a...
Your blanket probably caused an out of balance on the tub which caused the washer to stop in the middle of the cycle. The lock switch is a time delayed switch. Requires several minutes before it is activated to release. When washing single items you need to add another clothing item of approximately the same weight to create a balance during spin.
Dec 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer went haywire
Obviously, the control panel is indicating some type of error condition.
First thing to do is unplug the unit from the 120VAC power for about 10 minutes and plug it back in. See if this fixes the problem.
2nd thing I'd check is the ribbon or molex connectors on the back of the control panel. Re-seat them.
Mar 06, 2009 | Washing Machines
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Soak/prewash led flashing after about 10 seconds...
It is a pressure sensor fault, call in an expert to fix, these machines are far too complex for anyone else to repair Good luck
Feb 21, 2007 | Miele W310 Front Load Washer
Trouble starting Cycles
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
60 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
