Question about Baby Gear
Throw in colors?? - Baby Gear
How to rectify my hair colour used xxl absolute platinum roots are a lovely colour but rest of hair is orange suggestions in what i can do to rectify the problem
Where you tinting / coloring over a existing color?
It is real important that you navigate / calculate what your natural color level and what natural reflect your hair is. (Not artificially from a previous tint) Because tint is not total matt coverage like paint. Hair color wont tint over tint accurately. This is how many horrific bad colors are born.
If your eyes are blue or hazel & you have a fairer complexion that color is more feasible. If your eyes are brown and your hair is medium to coarser texture and very dark its a lot more complicated because you could throw scaling down (backwards) from lots of red to brassy copper to gold.
The actual formula needed is calculated on how many shade levels of lift counteracted by what reflect your lightened hair will throw. Not necessarily by what color the tint box says. The color shade on the box is a idealistic situation. If your having trouble following me or these complexities cut about 50 strands of hair at the nape (back of neck underneath your hair and put scotch tape around it. Then mix a minute amount of color and developer and you will understand me. This way you can at worse only screw up of 50 strands of hair (instead of everything attached to your head). Bad hair color jobs are expensive to fix & as I can see what we are working with a guess is a hazard. Don't take on almost mission impossible blindly.
Jun 04, 2014 | Schwarzkopf Essensity Permanent Hair...
I want my hair this color by wella
Apr 07, 2014 | Wella Professional Hair Color & Developer...
Colors don't print correctly. such as green prints as red. what's messed up?
The color cartridge for this printer has three colors (cyan, magenta, and yellow) within it. So if one runs out or is dried up if throws the color out of wack. Try running the head cleaning first but replacing the color cartridge should correct the problem.
Aug 09, 2010 | HP DeskJet 930c InkJet Printer
Get sound no picture lots of colors flashing
What king of TV? "DLP" your DMD board. Just throw tv out. Expensive, $300-800 and a SOB to install. If a LCD it is your T-CON/LCD control
board. Somewhat simple to install. Runs about $60-175 depends on brand and size of tv. It over heats and causes weird colors"floresent colors,colored bars,or the sereen to go hay-wire plad/stripes go bright/dark. Try Shop Jimmy for used/recon. parts. Hope this info helps. Todd
Jan 01, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
NO PICTURE ON MY FLAT SCREEN TV, JUST SOUND
TV has sound but no picture. Earlier it started flasing differnt colors then went black. Whats up can it be fixed or do I need to throw it away?
Oct 24, 2009 | Dell W4201C 42 in. Plasma HDTV
Printer not printing true to color color not the same as on screen
You might need to re-calibrate your screen. Even if this is performed it's not going to be 100% accurate unless your using pms color swatch sample as a guide. I would also check and see if you're using the correct paper to your printer's settings...this also may throw off the color. Hope this helps.
Sep 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
I want easyshare photo printer COLOR CARTRIDGES.where do i get em
No. Simply use the paper when you get new color cartrides.
Jun 21, 2009 | Kodak EASYSHARE 300 Photo Printer
Colors on my samsung projection tv are not aligned. how can i fix?
Any color gun has a value about 175 +- dllrs. to get the tv back to nornal one need to be replaced maybe two: Plus labor 250 average. An estimate can get you the best idea what to do.
Apr 24, 2009 | Samsung HCL4715W 47" Rear Projection...
Baby Gear Logo
70 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
